August 23, 2010, 17:09 |
Volume mesh error?
Modeling a somewhat difficult to model _Specially in gambit _, 3D weir
now in the last step , meshing the volumes it Gambit shows this error any suggestions? |
August 24, 2010, 01:06 |
Maxime Perelli
Rep Power: 41 |
If you read the error message, it says that you have surface mesh with high skewness.
Check where are those surfaces and fix the problems.
In memory of my friend Hervé: CFD engineer & freerider |
August 24, 2010, 02:27 |
i have read that
didnt know how to find those faces there are lots of faces in the model |
August 24, 2010, 02:37 |
Maxime Perelli
Rep Power: 41 |
in Gambit go to examine Mesh.
Since volume meshing has failed, you can go to examine mesh and choose 2d element. Then set the lower value to 0.9 for instance, it will display all the 2d elements with skewness over 0.9 Sometimes Gambit mentions which surfaces give you problems (in the error message you got, try to see if gambit mentionned any surface mesh failed or something like this).
August 26, 2010, 07:15 |
ok
ill try this thanks to the tips |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
