September 1, 2010, 21:40 |
Cart3D Problems
Stuart Buckingham
Rep Power: 26 |
Hi all,
I'm having problems running Cart3D on anything. None of my models or the "sample" models included in the icem install directory will mesh in Cart3D. I have tried on both x86 Windows XP and x64 Windows 7 systems. Both computers run ICEM CFD 12.1. After clicking "compute parameters", i get the following messages with no errors: "C:/Program Files/ANSYS Inc/v121/icemcfd/win64_amd/icemcfd/output-interfaces/df2cart3d" -i "./plugs.uns" -o vcarta -single Total Number of Nodes = 5646 Total Number of Elements = 11280 Number of Sections = 1 Reading Nodes... Section #0: Element type = 8, start = 5646, end = 16925 Number of Tri Elements = 11280 Reading Tri elements... Writing the family info... Number of components = 3 component 0: id = 1, name = PLUG-3 component 1: id = 2, name = PLUG-1 component 2: id = 3, name = PLUG-2 Building connectivity information... Orienting Normals ccw for whole... 0 Normals Reversed for whole Writing cart3D trifile: vcarta.i.tri... df2cart3d finished Created 4 New Cart-3D density polygons When running the actual generator, i get this readout: Running: "C:/Program Files/ANSYS Inc/v121/icemcfd/win64_amd/icemcfd/cubes" -i vcarta.input -o vcarta.mesh -ascii -b 4 -a 20 -pre vcarta.cntl -no_est -icem vcarta.dom -Dcut -Xcut 3 -Ycut 3 -Zcut 3 -no_file Program is running: pid = 2104 Application is finished. Error: Cart-3D Did not create pre-view mesh Loading domain "./plugs.uns" ... I hope somebody else has been able to resolve this issue already. Thanks, Stuart |
December 13, 2011, 22:11 |
Jie
Rep Power: 16 |
Hi stuart23
Have you solved your problem with Cart3D? I am getting into the same problem now. Jie |
cart, cart3d, cartesian |
Needed Benchmark Problems for FSI | Mechstud | Main CFD Forum | 4 | July 26, 2011 12:13 |
Two-phase air water flow problems by activating Wall Lubrication Force | challenger85 | CFX | 5 | November 5, 2009 05:44 |
Some problems with Star CD | Micha | Siemens | 0 | August 6, 2003 13:55 |
Airpak: Problems with heat flow contour conditions | Ivan de Miguel Urain | FLUENT | 1 | November 16, 2001 09:36 |
Inverse problems | Aleksey Alekseev | Main CFD Forum | 0 | May 12, 1999 15:38 |
