[ICEM] Specifying Periodic Vertices Causes Strange Problem |
September 2, 2010, 15:59 |
Joshua Counsil
Hi all -
I'm encountering a strange problem when I try to create periodic sides on a 3D airfoil. I have a working, complete 2D mesh that ran successfully (shown below). I want to create a 3D mesh with periodic sides. The span length is 100.85531 mm. First, I went into the Global Mesh Setup and defined a translational periodicity with the z (span) offset as 100.85531. I then extruded my 2D blocking scheme to 3D using a z translation of 100.85531. So far, so good. The problem arises when I begin specifying my periodic vertices. The vertices in the outer boundaries (inlet, farfield, outlet) don't seem to cause problems. The inner vertices (around the airfoil), however, seem to cause the mesh to extrude itself in the opposite direction desired (see below). The first picture shows the proper extrusion. The next pictures show the problem areas. Is my strategy incorrect? Any suggestions? Thanks! Josh |
A Strange Problem in making Parallel (Ansys/CFX 12) | a.sarami | CFX | 13 | October 7, 2010 01:33 |
problem in meshing a periodic boundary | dumas | FLUENT | 4 | March 8, 2006 10:54 |
Periodic Boundary Condition problem, help | arhgang | FLUENT | 7 | October 31, 2001 07:22 |
MRF problem | you | FLUENT | 1 | May 15, 2001 23:09 |
Problem with periodic boundary layers | Phil | FLUENT | 15 | October 2, 2000 14:56 |
