[ICEM] prism element on interface
Like Tree2Likes
  • 2 Post By PSYMN
Old   September 8, 2010, 23:05
Default prism element on interface
jai
jaikrishna
jai is on a distinguished road
prism element creation on fluid-fluid interface is good practice or not?
pls explain.
jai is offline   Reply With Quote
Old   September 9, 2010, 03:36
AB
BrolY will become famous soon enough
I'm not sure I have well understood your question. Anyway :
Prism elements are mainly used to better capture the boundary layer. If it is your goal, you don't need prism elements on the fluid interface.
BrolY is offline   Reply With Quote
Old   September 21, 2010, 16:46
Default finely capture gradients normal to the surface
PSYMN's Avatar
Simon Pereira
More generally, Prism elements are used when ever you want to finely capture a result gradient in one direction, but not others. The prisms allow you to refine in the direction normal to the surface without needing to refine along the surface (efficient use of mesh).
Do you expect gradients normal to your fluid/fluid interface? Do you want to resolve these closely?
For instance, if it was a free surface between the water and air, prisms could help to capture that wave motion.
Another possibility may be heat transfer between the fluids...
So yes, if you want to capture a normal gradient, prisms are a good idea.
If you don't expect anything, don't bother with prisms.
gaza and Anna_Zhang like this.
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
ICEM 5.1 to CFX Prism Element ashish CFX 1 April 6, 2005 18:32
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
