[ICEM] Overlapping elements on big radius
Old   September 13, 2010, 07:12
Default Overlapping elements on big radius
gajemon is on a distinguished road
There is a problem with overlapping elements on big radius (pic1).
I tried:
1. split block on radius (pic2)
2. assosiate edges and vertex with radius curve (pic3)
but there is no result
How can I fix it?
Thanks for your help
gajemon is offline   Reply With Quote
Old   September 14, 2010, 07:06
jeevan kumar
jeevankumarb is on a distinguished road
hello gajemon,
This can happen with improper extraction of curves from surfaces, or with bad geometry.
you can try
1. check the curves and the surfaces at that location where you have problem, try to extract cruves once again.
2. if it doesnt work you can try using interpolate option in the face assotiation. image attached, and select the two alternate faces where you have problem.
thank you
jeevankumarb is offline   Reply With Quote
Old   September 21, 2010, 14:53
Default Projection Limit
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
The best fix for curves and surfaces not quite lining up is turning on "Settings => Meshing Options => Hexa/Mixed => projection limit" This will interpolate just across the gap and not for the entire face...
However, this problem looks more like overlapping. It is pretty strange.
Oh well, I can't tell from here. Try the projection limit and other suggestions. If it still doesn't work you could post your model (or send it to me privately) and I could take a look when I have time. Or you could send it in to techsupp@ansys.com
PSYMN is offline   Reply With Quote
[ICEM] Overlapping elements Anorky ANSYS Meshing & Geometry 6 November 6, 2017 08:22
elements, nodes and faces Andy CFX 10 July 7, 2013 22:40
[ICEM] How to eliminate overlapping elements? ringtail ANSYS Meshing & Geometry 5 October 5, 2010 19:22
Penetrating elements in extruded mesh Michael P CFX 2 May 20, 2005 08:06
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
