[ICEM] Hex Edge Mesh Ignored by ICEM
Old   November 24, 2010, 15:09
Default Hex Edge Mesh Ignored by ICEM
W.N. Anderson
Will Anderson is on a distinguished road
Any ideas as to why the lone edge in the image below has no mesh nodes on it, despite the fact that I declared its edge meshing and copied parameters from it to all parallel edges?
Will Anderson is offline   Reply With Quote
Old   November 25, 2010, 09:04
AB
BrolY will become famous soon enough
It looks like it is an association issue. Remove your curves associations of this part, and redo them.
BrolY is offline   Reply With Quote
Old   November 27, 2010, 11:20
Default associate Edge to wrong curve...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Right, The edge has been associated to the curve or point on the left side, so all its nodes are jumping to the nearest point on the curve it is associated to...
To check this another way, right click on "Edges" in the display tree and turn on the option for "Bunching". You will see a green arrow from the problem edge to where it is associated...
To fix this, just go back to the associations DEZ and associate edge to curve... (or just hit the hotkey "p" while on the blocking tab). Select the problem edge and the curve behind it... Hit apply. If this is part of a longer series of edges associated to a series of curves, you could select the multiple edges and then the multiple curves they are associated to...
That should sort you out...
Simon
PSYMN is offline   Reply With Quote
This mesh contains patches of type empty but is not 1D or 2D oric OpenFOAM Running, Solving & CFD 36 November 28, 2016 07:12
mesh from icem cfd to cfx, how? Rogerio Fernandes Brito CFX 17 April 18, 2016 03:34
Export 2D mesh from ICEM to Fluent BuilttoSpill ANSYS Meshing & Geometry 4 August 28, 2010 08:16
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
CFX mesh & ICEM mike CFX 3 April 27, 2006 15:27
