GAMBIT Error Msg database file not properly closed
Old   October 7, 2009, 13:55
Default GAMBIT Error Msg database file not properly closed
Jan
Janomano is on a distinguished road
everytime I try to open files with Gambit I created and saved before, the following error msg appears: "ERROR: This Database file was not properly closed".
I couldn't find anything on the internet about that error, which leads me to the assumption that I did something really stupid so that I am the only person in the world who has to deal with this problem.
I use Gambit 2.4.6 on a Red Hat Enterprise Linux Version 5.3.
Thank you for your help!
Jan
Janomano is offline   Reply With Quote
Old   October 7, 2009, 15:02
hashem
hashem_1064 is on a distinguished road
Hey Janomano
Somtimes when Gambit suddenly is been closed, a file with the same name as your project but with the suffix ".lok" is created. I think your problem might be caused so. try to find such a file and delete it.
Hashem
hashem_1064 is offline   Reply With Quote
Old   October 7, 2009, 16:32
Jan
Thank you for your help, but unfortunately it must be something else. The .lok file disappears when I exit Gambit. Everything seems to be normal, three files are created, filename.jou, filename.trn and filename.dbs, I just can't open them anymore...
Does anybody have another idea?
Old   October 8, 2009, 02:33
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
I had the same problem under XP, if I tried to open a .dbs file from scratch folder (for instance: GAMBIT.3544)
Now I am not sure Gambit creates such folder under linux (I never paid attention) and if you are trying to open dbs file from this folder
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   October 8, 2009, 10:35
Jan
Yes, Gambit creates these folders under linux, too. But the problem seems to be independent from the saving directory. I just sent a saved file to a friend's computer and he cannot open it either, so I guess the issue is really with the saving part, not the opening part.
But again, thank you for your tips so far!
Old   October 8, 2009, 11:55
-mAx-'s Avatar
Maxime Perelli
Copy and paste the journal file (*.jou) especially the 5-first and the 5-last lines
Old   October 9, 2009, 10:48
Jan
This is an example .jou file I saved today.
/ Journal File for GAMBIT 2.4.6, Database 2.4.4, lnamd64 SP2007051420
/ Identifier "default_id"
/ File opened for write Fri Oct 9 10:07:28 2009.
volume create width 2 depth 2 height 2 brick
save name "/afs/umich.edu/user/j/a/janland/Desktop/test.dbs"
Another interesting thing: If I save a file, exit Gambit, reopen Gambit and load the file, it works. But once I try to open the file on a different computer or try to open other files I saved before or log off and then log in again and try to open the file --> error.
So I guess the problem might not be with Gambit itself but with some crazy linux stuff I don't know anything about... Do you have any ideas?
Old   October 9, 2009, 10:59
Jan
Here is another .jou file where I tried to open an old dbs-file.
After the error occured (line 4 + 5) I created some random stuff again and saved it.
/ File opened for write Fri Oct 9 10:51:12 2009.
/ERROR occurred in the next command!
identifier name "/afs/umich.edu/user/j/a/janland/save.dbs" old nosaveprevious
volume mesh "volume.1" map size 1
save name "/afs/umich.edu/user/j/a/janland/Desktop/again.dbs"
/ File closed at Fri Oct 9 10:52:20 2009, 0.35 cpu second(s), 2731264 maximum memory.
Old   November 23, 2010, 04:14
Default I face the same Problem..
Kamran
kamran651 is on a distinguished road
Hey J...did u find the solution to your problem..coz i am facing the same error...i dont know what it is..im using XP..
kamran651 is offline   Reply With Quote
gambit 2.4.6 error msg
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 06:43
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
Gambit Journal File Scripts, Public Database Needed? Jonas Larsson Main CFD Forum 13 March 2, 1999 07:25
