Error: Operation would result in Non-Mainfold geometry
Old   December 8, 2010, 10:40
Default Error: Operation would result in Non-Mainfold geometry
fergal is on a distinguished road
I am setting up steady-state turbine model. I firstly created the turbine blade surfaces with rhinoceros, then exported in solidworks and saved as a parasolid. I imported the geometry as a frozen solid and created a fluid domain around it.
However when I perform a boolean or body operation to cut or subtract the turbine material from the fluid domain I get the following error:
Error: Operation would result in Non-Manifold geometry
I tried basic geometries such as cylinders, cubes, etc., and I don't get any errors.
Is there a problem with the geometry before I imported it or is anyone aware of any solutions within Design modeller. (I have imported diagnostics in solidwork and amended any surfaces or gaps with the geometry)
Many thanks in advance for any help given.
Fergal
fergal is offline   Reply With Quote
Old   December 9, 2013, 08:04
Smile
Nazim
shahid nadeem is on a distinguished road
i am getting the same error while doing symmetry if you found the solution then please do inform me
shahid nadeem is offline   Reply With Quote
[ICEM] O-grid around wing geometry Anorky ANSYS Meshing & Geometry 15 November 27, 2017 13:43
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 04:53
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
Geometry show in Result Display ShFlow FLOW-3D 3 January 11, 2009 20:51
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
