Type of Contact for Fluid flows
Old   January 5, 2011, 13:49
Smile Type of Contact for Fluid flows
wawa
wawa is on a distinguished road
What type of contact should I use in ANSYS Workbench/ design modeler in order to specify a common boundary between two different fluid domain ?
Thanks.
wawa is offline   Reply With Quote
Old   January 8, 2011, 14:45
Default interior-Fluid2-Fluid2
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Some other experts may have other suggestions, but I would suggest you just set up Named Selections for each fluid body, plus a named selection for the inlet, outlet, symmetry, etc.
If you have bodies with named selections as Fluid1 and Fluid2, when you get to Fluent, you will also see boundaries for wall-Fluid1, wall-FLuid2, interior-Fluid2-Fluid2, or something like that.
PSYMN is offline   Reply With Quote
Old   January 8, 2011, 15:59
wawa
Hi PSYMN
But the issue is that to have a common boundary between two fluid or solid domains, I need to form a new part and imprint faces in Design modeler. Otherwise, when I send it to Fluent, I obtain 2 lines superimposed for the same boundary (not shadow walls), and this prevents a solution.
I was wondering whether you know how to have different parts in Design modeler, but solve them together in Fluent, without combining all parts & imprinting faces etc. This is so that it's easier to mesh in ANSYS Meshing.
Thanks.
Old   January 8, 2011, 16:31
PSYMN's Avatar
Simon Pereira
To have the parts with conformal mesh, you need to create a multi body part in DM. If you don't want conformal mesh (like a sliding mesh interface or other meshless interface), then you would expect two walls. This then becomes a solver question rather than a mesh setup one.
Old   January 10, 2011, 03:34
wawa
Ok,
But how will I set up the solver if I have a non-comformal mesh between a solid-fluid part that have a common boundary ?
Basically my problem is to solve a heat transfer problem between a fluid domain and a solid wall ( wall is constructed in Fluent), but I don't know how to set up a common boundary between the two in fluent, without forming a new part i.e. without conformal mesh, and imprinting faces.
Your help is very much appreciated.
Thanks.
Free jet simulation msarkar OpenFOAM Running, Solving & CFD 39 May 11, 2021 13:21
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
turbulent jet simulation antonio_ing OpenFOAM Running, Solving & CFD 5 September 16, 2010 02:31
buoyantSimpleRadiationFoam msarkar OpenFOAM 0 February 15, 2010 06:22
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
