trailing edge negative volumes
Old   January 19, 2011, 06:46
Default trailing edge negative volumes
Nick
Nick R is on a distinguished road
Hi guys,
I'm trying to mesh an airfoil with a sinusoidal leading edge using a simple blocking scheme with an O-ring. No matter how I move things around I always get negative volumes especially toward the trailing edge (see the images) I tried to get rid of the wedge behind the foil but didn't make much of a difference.
I'm quite a rookie and don't know how to fix these simple things. I'd very much appreciate your help.
Also any ideas about the blocking scheme for a wavy leading edge would be appreciated.
Nick
Nick R is offline   Reply With Quote
Old   January 30, 2011, 17:12
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
I can't see exactly what the problem is, but negative volumes mean that your blocking is probably tangled... Your verts may actually be crossing. Perhaps your upper edge is projected to the lower curve and vice versa?
Perhaps a CGrid blocking would be better than an OGrid.
As for the waving leading edge, with Hexa, you should focus on the topology, not the actual shape. A bent pipe is still a pipe, a wavey wing is still basically a wing. You don't need to block for those curves, just block as a normal wing and associate with the surface. The mesh will follow and interpolate nicely...
Here are some pics...
First the side blocking of the CGRID...
Then, since this model had a sharp trailing edge, I split behind the wing and collapse the trailing edge block...
A few more steps and here is roughly done... Note this is just a single wedge block associated with the more interesting airfoil. No extra blocking was done to capture the wavy leading edge.
The thing about hexa is to have fun with it...
PSYMN is offline   Reply With Quote
Old   February 2, 2011, 02:05
Nick
Simon!
This is really cool and sort of like what I made. How did you create the foil? I use Solid Edge. Is there a more efficient way? I had difficulty with creating the surfaces.
Thanks again.
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
[ICEM] Hole near sharp trailing edge of airplane/wing geometry jlichtwa ANSYS Meshing & Geometry 2 September 21, 2010 15:19
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
