[ICEM] Delaunay Maximum Size Control
Old   February 2, 2011, 21:55
Default Delaunay Maximum Size Control
William Humber
whumber is on a distinguished road
Has anyone noticed an issue where the delaunay volume mesher ignores the maximum global mesh size? I'm generating a surface mesh first using octree and then generating the volume mesh using delaunay, but the mesh seems to jump to the same maximum size no matter what size is set to the local or global max.
whumber is offline   Reply With Quote
Old   February 3, 2011, 11:37
PSYMN's Avatar
Simon Pereira
Does it jump to a size that is greater than the global max or smaller?
Old   February 3, 2011, 11:39
William Humber
Greater than the global max.
Old   May 24, 2013, 04:57
Pete
Tech Neo is on a distinguished road
I am having the same problem. Delaunay mesher creates tetrahedral elements with max side 4-5 times larger than the specified global max size! Tgrid does this too. Any suggestions why?
Tech Neo is offline   Reply With Quote
Old   May 27, 2013, 16:25
PSYMN's Avatar
Simon Pereira
I am not sure that the global max size applies to Delaunay or TGrid... It is really a setting for Octree...
Those other meshers use the surface mesh and grow into the volume from there...
However, I have controlled their max size with density boxes... Try that.
CFD Online Users Survey
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
