February 2, 2011, 21:55 |
Delaunay Maximum Size Control
William Humber
Has anyone noticed an issue where the delaunay volume mesher ignores the maximum global mesh size? I'm generating a surface mesh first using octree and then generating the volume mesh using delaunay, but the mesh seems to jump to the same maximum size no matter what size is set to the local or global max. |
February 3, 2011, 11:39 |
William Humber
Greater than the global max.
May 24, 2013, 04:57 |
Pete
I am having the same problem. Delaunay mesher creates tetrahedral elements with max side 4-5 times larger than the specified global max size! Tgrid does this too. Any suggestions why?
May 27, 2013, 16:25 |
Simon Pereira
Rep Power: 47 |
I am not sure that the global max size applies to Delaunay or TGrid... It is really a setting for Octree...
Those other meshers use the surface mesh and grow into the volume from there... However, I have controlled their max size with density boxes... Try that.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
