[GAMBIT] (HELP!) Gambit volume meshing error, Initialization failed, Perturbation boundary
Old   February 13, 2011, 02:22
Default (HELP!) Gambit volume meshing error, Initialization failed, Perturbation boundary
wibi ario
sincity is on a distinguished road
i'm trying to modeling 3D SYMMETRY BUTTERFLY VALVE, but i keep continue get an error message: "Initialization Failed, Perturbation Boundary..", from GAMBIT while i'm trying to mesh it. how can i solve this??please help!thanks.
( i can send you my 3D GAMBIT model)
sincity is offline   Reply With Quote
Old   February 14, 2011, 01:53
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
post a picture
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 14, 2011, 08:06
wibi ario
[IMG]file:///C:/the%20problem.jpg[/IMG]
here is my problem max..area in the circle that i cannot mesh it. i can send you my GAMBIT file if you want to help me
Old   February 14, 2011, 10:05
-mAx-'s Avatar
Maxime Perelli
The problem comes from your cylinder.
Indeed with this diameter, you have a problem at the top of your butterfly valve, because exactly on y-axis your valve has also same diameter.
Then you have very sharp angle which will crash meshing-process.
check edge.228 & edge.10
Old   February 14, 2011, 10:33
Default le
wibi ario
i know that max...that's the problem,
since i'm working with my butterfly valve with 75 degree opening angle model. i've tried in so many way but i couldn't find the solution, split it, reducing internal size, using size function, mesh edge..but they gave me the same error skewness.
how could i possible to mesh it succesfully, max?
Old   February 14, 2011, 12:05
-mAx-'s Avatar
Maxime Perelli
you can, for instance, increase the cylinder diameter (very small change in diameter), just for allowing one cell layer between cylinder and valve..
Than can be also a local extrusion, just in the neighborhood from rotation axis.
Anyway you need to change your topology
Old   February 14, 2011, 23:47
wibi ario
thanks max..your solution is work!
but is that ok if i change the dimension of my model??
Old   February 15, 2011, 01:08
-mAx-'s Avatar
Maxime Perelli
If you increase the cylinder diameter, you may also increase the "leakage" above the valve.
But as I said increase, I meant a very small change (in your tolerance)
If you think the gap is too important in respect of leakage, then you can split your domain at the valve (as you already did), an turned as small portion of your split surface as wall
Old   February 15, 2011, 06:37
wibi ario
i get it, thanks max..by the way, could i email you if i have trouble again??
Old   February 15, 2011, 06:52
-mAx-'s Avatar
Maxime Perelli
Post new thread.
If you email me, nobody can benefit from the solution (if I give a solution )
Boundary layer meshing problem in Gambit Crystal FLUENT 0 June 12, 2009 20:58
Boundary layer meshing problem in Gambit Crystal Main CFD Forum 0 June 12, 2009 14:32
Gambit: Volume Meshing fluentnoob ANSYS Meshing & Geometry 4 May 20, 2009 05:21
Failed in volume meshing MANOJKUMAR FLUENT 0 October 19, 2005 06:19
Initialization failed for volume meshing?? Ng FLUENT 1 March 15, 2005 08:00
