Arun Ammanath
Rep Power: 0 ![]() |
Hi all, i am trying to import a Submarine fairwater modelled on autodesk inventor to gambit to create the mesh, when i import the .stp file that i saved on autodesk inventor onto gambit it gives me an error saying units are in "mm or m" what sort of units do i need for this file to work on gambit.
Please let me know. |
Maxime Perelli
Rep Power: 41 ![]() |
Gambit doesn't have units-system.
If your are importing a brick 100mmx100mmx100mm, then you will have a brick with 100x100x100 in Gambit. You will be able to scale your problem when you import your mesh into your solver
In memory of my friend Hervé: CFD engineer & freerider ![]() |
Arun Ammanath
thanks,
But the translation error when i import the file from Autodesk inventor to gambit says "error input values mm", but never mind i did the pain staking task of creating the vertex's on gambit and then joining those to give me the same submarine sail ![]() |
Maxime Perelli
Then it was an error regarding the step import
Gambit geometry problem | cestrin | FLUENT | 3 | July 4, 2012 02:33 |
[Commercial meshers] Problem with Mesh conversion Gambit msh Foam | Rachid BANNARI (Bannari) | OpenFOAM Meshing & Mesh Conversion | 25 | September 11, 2011 07:58 |
Gambit installation problem | Panos | FLUENT | 4 | March 5, 2009 22:44 |
Problem meshing with Gambit | Adrian | FLUENT | 8 | October 7, 2008 08:39 |
Startup Problem in Gambit 2.2 with WindowXP | Win Win Maw | FLUENT | 3 | January 25, 2006 11:09 |
