[ICEM] Meshing a blade inside air volume
Like Tree3Likes
  • 3 Post By PSYMN
Old   May 5, 2011, 15:39
Default Meshing a blade inside air volume
LittleBart
LittleBart is on a distinguished road
Hi there!
I'm trying to make a good-looking mesh for my wind turbine study. It's a blade and 120 deg sector of surrounding air. The airfoil is linearized with shorty lines in order to eliminate high-order NURBS surfaces problem, which I had suffered much from previously.
I want to mesh it in ICEM but not sure what strategy to use for blocking. Actually there are too many faces with different angles and locations to do this manually. Is there any techniques to associate inner o-grid block to the blade surface with minimum movements?
LittleBart is offline   Reply With Quote
Old   May 6, 2011, 09:31
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
If you take a look thru my posts, we already went thru this with someone else and I posted a lot of blocking images...
Once your blocking is right, you may be able to snap fit (one click) the surface projected nodes around the airfoil down to the surface...
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   May 6, 2011, 10:52
LittleBart
Thanx for reply!
I've made a block as 3D bounding box around the air volume, then snapped the vertex to the corner points and linearized two top edges of the block to match the external surface of the geometry (it is seen on the second pic).
But then when I'm trying to use o-grid split, it always shows me "o-grid did not succeed" message and I'm not sure what to do, how to make o-grid properly?
I'll definitely look your posts through (doing now)...
thank you...
Old   May 6, 2011, 11:36
PSYMN's Avatar
Simon Pereira
Are you starting with a 3D block or just a surface block on the outside of the ff surface?
If you didn't start with a 3D block, try some of the hexa tutorials first before tackling this model or it will crush you
Old   May 6, 2011, 14:59
LittleBart
started with "3D bounding box" block initialization. The external faces were ok, but still don't how to make o-grid inside. It looks like that on th pic attached when I'm trying.
still can't find the mentioned thread with similar case .. can you remember may the topic or the threader's name or some clue...
Old   May 6, 2011, 16:03
Default Previous posts...
PSYMN's Avatar
Simon Pereira
You have collapsed the 3D block down to a wedge...
Don't do that.
Leave it as abox with three corners on corners and the 4th at the mid point of the arc.
Then Create the Ogrid with faces at the flat ends of the cylinder and the symmetry planes.
The previous thread was talking about "wind turbines"... I probably recommended "shifted periodic"... Some of the images had the name "Zaqie" on them... (that should give you some search terms)
here are some screen shots that were part of the previously posted threads.
Old   May 6, 2011, 16:16
LittleBart
Many thanks. The pics are grate... I remember the second one from the meshing tutorial but shifted periodic is not clear to me yet. I'm working on that.
Have found "3D turbine blade modeling" thread, processing...
Will definitely try and post here.
Old   May 13, 2011, 06:33
LittleBart
Hello Simon and everyone who is interested in such a case!
Thanks to your instructions to Zaqie, I was able to deal with blocking of my geometry. But I'v faced some problems because of slightly different geometry than this of Zaqie's.
1. I have little bit different orientation of the blade because of small angles of attack and pretty twisted shape (angle difference between the root and the tip is deg). Because of that the strategy proposed for blocking has lead to some messy regions on the tip and on long-chord sections after I had snapped all edges of these splits to the curves.
2. But still, this blocking topology allowed my to build and tune premesh and I'm pretty satisfied with that. That's how I learned edge settings and splitting skills
But when I'm trying to calculate surface meshes it ignores the premesh and is trying to calculate according to the predefined edge params and global sizing. Furthermore, when I'm trying to change the global sizing for parts it seams to ignore that and still trying to calculate with very high density which I don't want to have. I left my comp for a day calculating the mesh and I got it after 15 hours of calculations and its sizing was about 1 mm for the air part when global setting 100. Global mesh coeff is 1.
So the question is how to force the settings I gained in the premesh to become settings of the surface mesher and volume as the next step?
Thank you,
LittleBart
Old   May 14, 2011, 00:02
Ahmed
Ahmed is on a distinguished road
http://www.ara.bme.hu/~lohasz/ICEM_t...blade_mesh.pdf
Ahmed is offline   Reply With Quote
Old   May 14, 2011, 05:01
LittleBart
Thank you for reply and for the tutorial, it really was really helpful!
But it doesn't really show the transition from premesh settings to mesh params. Or I'm just do not understand the concept of premesh itself. Is it really like separate from the mash-tab mash and I don't need to calculate surface and volume meshes if I have pre-mesh done?
Here little context to make myself clear. I'm doing this mesh for my blade study which I want to do in CFX and therefore I want to output the mesh into CFX-readable file with separate regions for BCs.
So, do I need to calculate volume mesh on the mesh tab or I can just make premesh in bocking tab and then just output it into CFX file.
My apologies once again for probably stupid question but I'm really very new in it.
Old   May 15, 2011, 20:37
Default Convert to unstructured mesh...
  #11
PSYMN's Avatar
Simon Pereira
Yes, the premesh already has everything (surface and volume mesh), you just need to convert it into the right format for your solver. Check the quality while in premesh, make sure everything is good and then right click on Premesh to output to unstructured mesh...
Then do unstructured mesh checks, etc.
This unstructured mesh can then be output to CFX...
Simon
Old   May 17, 2011, 09:20
LittleBart
Hi !
Thanks Simon for help and patience! Little more question on unstructured mesh - will it preserve regions for inlet/outlet surfaces as separate 2D regions for CFX BCs ?
Btw, now I feel like ready for scripting, thanx to you .
Old   May 17, 2011, 10:46
PSYMN's Avatar
Simon Pereira
That is what PARTS are for...
If the blocking face is associated with (projects to) the geometry of part "INLET" then its premesh and subsequent unstructured mesh, will also be in the part "inlet". This is just the default behavior. When you output, the output will also have the faces in the inlet part ready for your bocos.
Simon
Old   June 22, 2011, 09:50
LittleBart
Hello everyone!
After long vacations I'm again face to face with my blade problem and again asking for your help. Thank to Simon now I can build relatively stable and adjustable unconstructed mesh for the blade. And now I'm trying to model the problem in CFX (13). Actualy, this problem is my old one, the one that made me turning to ICM CFD and master the Mesh Skill. Thats because I thought that the results I've received are bad because of the bad mesh quality.
In my previous problem I've made a blade geometry and meshed it with CFX Mesh. The CFX problem had the following parameters:
CF:
Z - rotational axis, X -
Domain:
1. Air - fluid domain - ref. pressure = 1 atm; fluid - air; CF - rotational cf with 13 rad/s velocity (expected velocity of the modeled blade at 10 m/s wind).
2. Blade - solid domain (Aluminum).
BCs:
1. Inlet - inlet surface of the air volume - Velocity = 10 m/s
2. Outlet - outlet surface of the air volume - Static pressure = 0 atm. (= ref. pressure)
3. External surface - wall - no slip wall (FF)
4. Side surfaces - domain interface Air/Air - rotational periodicity
5. Air/Blade - domain interface - fluid/solid - frozen rotor
That was the model. And these are the results:
But my main question is quality of the blade. In order to answer this question I've tried to evaluate the overall Lift Force of the blade and, as a result, Momentum or Torque. In order to compare this force with the one calculated with beam element theory.
I've calculated this with an expression
aveInt(Force X)@Blade_surf
and got the value of 13.4 N
Which made me sad.
And now I've made the same procedure with new mesh and result is 12.5 N which is proximately the same.
to be continue...
Old   June 23, 2011, 03:51
LittleBart
yeaah.. I'll better repost it to the CFX section
Old   October 7, 2012, 10:43
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Simon
Is there any difference between the quality in pre-mesh and unstructured mesh (which is also created from that premesh)?
Far is offline   Reply With Quote
Old   October 8, 2012, 03:44
AB
BrolY will become famous soon enough
I think the pre-mesh doesn't check the quality for quads.
But the quality for unstructured mesh does check the quality for quads, unless you specify not to.
BrolY is offline   Reply With Quote
Old   October 9, 2012, 17:53
PSYMN's Avatar
Simon Pereira
Yea, depending on the metric, there may be some small differences that you will see, and some metrics are only available in one, but not the other. Or as BrolY says, the unstructured quality can include the quality of Quads or other element types.
The important thing is just to be reasonably confident that your mesh is good enough for your solver before you bother moving the files around.
Old   October 10, 2012, 05:51
Tamil Nadu
nkme2007 is on a distinguished road
Hello All,
I want to do analysis of heat transfer from water flowing through pipes submerged inside concrete. I am modelling in GAMBIT and wish to analyse it on Ansys FLUENT.
Can anybody help me out, how to model and simulate?
Does any tutorials exist?
nkme2007 is offline   Reply With Quote
Old   October 10, 2012, 09:20
PSYMN's Avatar
Simon Pereira
@ nkme2007
You hijacked a bunch of different threads with your question, please don't do that. it is annoying. Particularly when you jump on threads for ICEM CFD or ANSYS Meshing (we don't know much about Gambit anyway)...
Just create your own thread or possibly find a Gambit thread with a similar question and replay to that.
But in the end, you probably won't get any help anyway because your question is too broad, you may as well say "how do I do CFD?" Try some Fluent tutorials and start on your project. CFD-Online helps those who help themselves.
Far, BrolY and aero_head like this.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Gambit: Volume Meshing fluentnoob ANSYS Meshing & Geometry 4 May 20, 2009 05:21
Volume split -- Meshing Kantipudi FLUENT 0 July 27, 2008 12:18
Question on blade meshing Jeffrey CFX 0 March 7, 2008 17:13
