[ICEM] mesh trailing edge wedge
Old   June 22, 2011, 05:17
Default mesh trailing edge wedge
Mike
josip76 is on a distinguished road
hi im hoping someone could take a look at my mesh of a transonic airfoil with a trailing edge wedge and tell me what they thought. If there maybee is a better way to capture the geometry around the wedge? I used a structured hex mesh.
pic of mesh around trailing edge wedge
and heres a pic of the blocking structure around the airfoil if ur interested to see this
Thanks for any input
josip76 is offline   Reply With Quote
Old   June 22, 2011, 06:08
jeevan kumar
jeevankumarb is on a distinguished road
Your blocking and the meshing is perfect only there is cell jump near the TTE, just correct the bunching near the tte.
jeevankumarb is offline   Reply With Quote
Old   June 22, 2011, 06:40
Mike
hey thanks for ur reply, ya i'll match the edges in the horizontal direction along the flat trailing edge surfce and maybee add some more nodes there. Thanks for ur input
Old   August 28, 2013, 21:02
nvtrieu is on a distinguished road
Could you show me the full domain and the final mesh?
what is the y+ value?
Thank you very much.
nvtrieu is offline   Reply With Quote
Old   August 31, 2013, 15:59
Cesar
cesarcg is on a distinguished road
Send a message via Skype™ to cesarcg
I think that you would control the cells behavior around the wedge trailing edge if you add a cut in the pressure side of the blocking as close as possible to the 6th point from right to left. Then adjust the edge of the new blocking in order to increase the orthogonality of cells near this area.
Regards.
cesarcg is offline   Reply With Quote
Old   September 1, 2013, 11:12
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
The thread is two years old...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   September 1, 2013, 12:31
Cesar
I did not notice that haha...
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
How to refine the mesh near the Trailing Edge in TurboGrid BalanceChen CFX 0 March 3, 2011 03:53
[snappyHexMesh] trailing edge not snapped perfectly.. ahsangzl OpenFOAM Meshing & Mesh Conversion 0 March 2, 2011 12:49
