August 4, 2011, 07:57 |
Formatted point data issue
Gon
Rep Power: 14 |
Iīve been reading every post related to importing coordinates to either icem or design modeler. However, I havenīt solved my problem at all. I followed the format given in icemīs help to import points, and I always get a "nothing visible" text line, and no geometry is showed. Please Iīm trying to do my thesis simulating flow around an airfoil and I canīt start because of this, if someone could send me a valid file with coordinates I think could be enough. Thank you |
August 11, 2011, 18:24 |
Prakash Paudel
Rep Power: 15 |
sounds like you need to check points, curves and surfaces under Geometry in model tree
matching variable data with grid point data | anfho | OpenFOAM Programming & Development | 0 | May 6, 2011 15:28 |
How to put melting point data of inert particle in DPM model of Fluent | subhankar_bhandari | FLUENT | 0 | July 28, 2010 07:40 |
How to put melting Point data of inert particle in DPM model | subhankar_bhandari | Main CFD Forum | 0 | July 26, 2010 07:28 |
Point cloud data | ms | Main CFD Forum | 1 | July 25, 2006 16:54 |
Passing point data to UDF using C_UDMI | Sam Bennett | FLUENT | 6 | December 1, 2005 08:46 |
