June 27, 2011, 18:38 |
Design Modeler Boundary Condition
Nathan
Rep Power: 15 |
Hi
I want to model a channel with four segments attched to eachother. I name the boundaries in the design modeler in order to define them later in Fluent, the problem is that names are not transfered to the meshing program in the ansys workbench and it is difficult to recreate the names in there as it is a 3D model with some boundaries inside the channel. Anyone can help me with this? Thanks alot! |
June 28, 2011, 00:09 |
anonymous
Rep Power: 14 |
If your trying to name the boundaries in CFX-Mesh then the easiest way it to right click outer boundaries in the tree menu on the left side and "hide" the boundaries. this will let you see everything inside. If that's not your issue i am not sure. Good luck
June 28, 2011, 02:32 |
Zhang Yang
Rep Power: 15 |
You can do the followings:
Workbench Pannel -> Tools -> Options -> Geometry Import -> click Named Selections and delete the Filtering Prefixed. So that the Name you defined in DM will transfer to the Ansys Meshing It is better to define all the Boundaries in DM, because in DM you can hide the faces you want by right - clicke Hide Faces, when you put your cursor on the faces you want to hide. |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Can anyone give me some hint on how to make traction free boundary condition? | poplar | OpenFOAM | 3 | January 14, 2015 02:37 |
Setting outlet Pressure boundary condition using CAFFA code | Mukund Pondkule | Main CFD Forum | 0 | March 16, 2011 03:23 |
How exactly the "pressure outlet" bdry condition compute properties on the boundary? | yating9901 | FLUENT | 3 | June 28, 2010 12:26 |
How to set boundary condition in Fluent for the fo | Peiyong | FLUENT | 1 | November 10, 2006 11:44 |
