[ICEM] Hexa Prism layer NOT USING hexa (Blocking tab)
Old   July 3, 2011, 19:29
Default Hexa Prism layer NOT USING hexa (Blocking tab)
la7low is on a distinguished road
Hi Everyone,
could someone tell me how to create hexa prism layers (rextangular bricks) or quad elements extruded to a hexahedral elements (distorted bricks)? Ive always used blocking method before but now I must use volume/surface/prism meshing methods on a 3d geometry...
I have another question: how to create such a mesh on a 3d wing (again not using blocking) as depicted there (http://www.cfd-online.com/Forums/ans...tml#post258691) on the 4th pic?
How can you tell the prims mesher to just stop at a point without stair stepping? For me either you tell Icem prism generator to do stair stepping and you give up the boundary layer resolution (middle picture) there or you uncheck stair stepping getting crap like that on the left and right pictures.
Any help would be greatly appreciated!
la7low is offline   Reply With Quote
Old   July 5, 2011, 09:30
PSYMN's Avatar
Simon Pereira
The problem is that if you don't stair step, but transition directly to tetras, you have very thin pyramids right up against the tetras and the tetra quality is very poor. If you want to do that, you can force a remesh by selecting those pyramids (and a few tetras attached) and remeshing them with tetras (Edit Mesh => Remesh => Subset).
I recommend a 4th option... Try the trailing edge baffle (as you did on your 3rd image), but with stair stepping... This will taper off the prism layer along the baffle.
To take it one step further, you could actually transition the initial height along the baffle. To do this, make sure you don't set an initial height on the baffle its self, but rather set the height on the curves. On the wing trailing edge side, set the small initial height that you set on the wing. On the other end of the baffle, set a larger height that will allow for easier transition to the volume...
CFD Online Users Survey
Old   July 5, 2011, 12:18
I could make this (1st picture). My probem with this idea is that it does stair stepping at the free tip too as seen on the 2nd picture below. It would be important to maintain the resolution of the boundary layer there.
So I rather liked your first suggestion to remove the prisms and then remesh it:
I assume you were referring to Edit Mesh => Repair Mesh => Remesh Elements . Is that right at the first place? I could not use that tool. First of all, how to select the pyramids and some surrounding tetras? I could put all pyramids to a subset by turning on the visibility of Pyramids under Mesh-Volumes, then by right-clicking Subsets => Create I could put the visible pyramids to a subset. But how to add some nearby tetras to it?
Then I went Edit Mesh => Repair Mesh => Remesh Elements. There I opted for the followings:
Mesh type: Tetra
Elements: the subset I created (without tetras nearby)
Part: Inherited
Surface Projection/ Ignore Projection was left unckeched
Unfortunately, the pyramids were barely replaced by tetras (look at 3rd picture)...What should I do different?
Thanks for the help!
Old   July 8, 2011, 01:43
Default Success but further questions..
I could make it, see picture below. I even scripted it and have a question about the "ic_uns_subset_add_pick_polygon" command. Its arguments are: "what name poly vect from_names partial convex etype [""]".
What is "vect"? I could not figure it out and Programmer's Guide only says: "Add elements in a screen polygon area to the subset, what can be one of edge, node, element, or a list of one or more of 0d, 1d, 2d, 3d."
In addition, I still welcome suggestions on how to extrude Autoblock surface mesh to layers containing hexa (topic title)? For me the prism layers always die prematurely when starting off with all quad surfaces...
Thanks for the help so far!
Old   July 11, 2011, 15:49
PSYMN's Avatar
Simon Pereira
Vect is probably the screen view vector...
The polygon select assumes that you are viewing the polygon from a particular orientation (normal to the screen), and so needs a direction vector...
Old   January 28, 2012, 23:50
Ming Cai
mingersai is on a distinguished road
Would you please tell me how you did this?
mingersai is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh - no layer added bejbro OpenFOAM Meshing & Mesh Conversion 5 February 1, 2020 20:05
[ICEM] Creation of hexa dominant mesh and prism layer gnuboard ANSYS Meshing & Geometry 7 January 11, 2018 04:13
ICEM Prism Layer transition between surface with prism layers and one without TWaung ANSYS Meshing & Geometry 2 October 12, 2009 14:56
Trimmer & prism layer peresah STAR-CCM+ 6 October 6, 2009 14:39
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
