August 18, 2011, 07:09 |
Double pipe heat exchanger
Mohsin
I am trying to model a double pipe heat exchanger but whenever I try to mesh that model there is an error comes up as ' mesh exporter does not support overlapping geometry problem'. I dont know how to resolve this issue. Kindly help to resolve this issue. Regards, Mohsin |
August 18, 2011, 07:48 |
Maxime Perelli
Rep Power: 41 |
post picture
In memory of my friend Hervé: CFD engineer & freerider |
August 18, 2011, 10:04 |
Mohsin
I have solved that problem for the model in which both the fluids are water but if I used the model like : Inner fluid = hot water Inner pipe = copper outer fluid = Phase change material (solid) outer pipe = copper then it gives errors like Access Violation? Thanx Regards mohsin |
August 18, 2011, 10:12 |
Anjaneyulu Nanduri
[QUOTE=mohcin;320604]Hi,
hi, it is a double domain channel, so 2 domains are necessary for flowing, first create a geometry a pipe in pipe, import that cad file into icem, declare all fields, inlet_1,outlet_1, inlet_2, outlet_2. first take a material point in inner pipe mesh it, and take another point and mesh it next. |
Double pipe heat exchanger | mohcin | FLUENT | 21 | June 18, 2016 14:19 |
Continuing User Defined Real Gas Model issues | aeroman | FLUENT | 6 | April 8, 2016 03:34 |
how to analysis double pipe heat exchanger in cfx | rammax8 | CFX | 12 | February 14, 2014 16:10 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 11:48 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
