June 28, 2013, 13:19 |
#21 |
Simon Pereira
Rep Power: 47 |
Agreed... You should try ANSYS Meshing with patch conforming meshing if you want to get your Gambit Size function like behavior back.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
June 29, 2013, 10:10 |
#23 |
Simon Pereira
Rep Power: 47 |
Sort of... It was implemented in Multizone. Multizone uses the Hexa framework, but when you have an unstructured block or paved face, it can use the gambit sizing function...
But I don't expect we will be hooking up the Gambit sizing function to the patch conforming mesher directly... Instead the direction is forward with ICEM CFD technology being hybridized with gambit (and other) technology in future products. This is probably because users who want surface mesh to respect a sizing function can just use patch independent in ICEM CFD, which does respect the sizing function and also includes patch independence.
June 29, 2013, 10:20 |
#24 | |
By "Size function" you mean Curvature/Proximity Based Refinement?
ICEM, CFX and Fluent expert |
June 29, 2013, 10:22 |
#25 |
Simon Pereira
Rep Power: 47 |
Yes, that is the ICEM CFD size function. It works with patch independent tetra and surface mesh.
June 29, 2013, 10:25 |
Question
#26 |
But it is different with Gambit Size Function except for name.
June 29, 2013, 10:47 |
#27 |
Simon Pereira
Rep Power: 47 |
Yes, the ICEM CFD and Gambit Sizing functions are different code, independently developed, but for the same purpose.
TO me, the main difference is that the ICEM CFD tetra mesh is octree, and the mesh actually shows the sizing function directly. With Gambit, they actually run a size function controlled octree in the background and then use that to indirectly guide the patch conforming and delaunay mesh generation. So the difference is less about the size functions and more about how the mesh uses the size function.
June 29, 2013, 10:57 |
#28 | |
But the gambit mesh stick (and more uniform) more to surface as compared to ICEM even though they are also using octree, denauly etc. e.g. mesh on high aspect ratio wing
I thought gambit needs the surfaces mesh first and that is patch conforming (as gambit is bottom up mesher). When it uses dalaunay mesher? |
June 29, 2013, 11:38 |
#29 |
Ok. Here is full tutorial on hybrid 2d meshing in ICEM CFD. Everything is attached with post. Hope you will like it.
https://dl.dropboxusercontent.com/u/..._2dairfoil.rar |
June 29, 2013, 13:24 |
explanation
#30 | ||
But the point is in 3D cases, with a little more job, by making nested densities we can get that size function. And it is actually just similar to what we get in gambit. Quote:
June 29, 2013, 13:36 |
#31 | |
And then they take it to icem where they create geometry and insert 3d prism layers which is almost impossible in Gambit. What I feel is that with ICEM Octree and patch independent surface mesh you can mesh a very complex geometry within few hours while in gmaibt you need detailed working in defining size functions for edges, surfaces and volumes. Sizing on each edge. Still Gambit has difficulty in making volume mesh. Moreover it does not support heavy meshes and hangs often. Only requirement of ICEM is that you should know the appropriate settings for your model which I find some times difficult to get in first place. |
January 9, 2014, 10:26 |
#33 | |
Rep Power: 12 |
Since your curve has a varying slope, you can't have a perfect boundary layer jus by scaling. If you look carefully the boundary layer which Andrea did, the distance between BL and geometry varies. You can have a fine BL by scaling with different x and y offset coefficients. If you want a perfect BL, you can do it following this steps: 1) You should know the equation of your curve or at least coordinates of points. 2) Then you can find slopes at given points by taking the first derivative of your curve equation or numerically deriving by using points. 3) Then calculate your max boundary layer thickness by using BL equation. 4) Find the points which will lay on your boundary curve by using the slope at each point and BL thickness. I did it in excel. It takes time but, for me it was the only way to do it. Last edited by kozalp; January 9, 2014 at 10:28. Reason: corrected a writing error |
November 18, 2019, 09:15 |
#34 | |
Anup Jain
Rep Power: 7 |
I am not able to open the file. Can you please share it again? |
[ANSYS Meshing] Creating Hex Boundary Layer Mesh and Unstructured everywhere else | NLao | ANSYS Meshing & Geometry | 1 | March 15, 2011 06:35 |
Not able to mesh a helix with boundary layer using gambit | rohitjvbibin | Main CFD Forum | 0 | March 5, 2011 11:28 |
Not able to mesh a helix with boundary layer using gambit | rohitjvbibin | ANSYS | 0 | March 5, 2011 11:27 |
Dynamic Mesh with Boundary Layer | Marcell | FLUENT | 0 | March 11, 2009 08:40 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 13:20 |
