[ICEM] Cylinder Geometry and Blocking
Old   November 18, 2011, 13:45
Default Cylinder Geometry and Blocking
Leepox is on a distinguished road
I'm a complete ICEM newbie (just started learning a week ago) never did any 3d models before or in that case, meshing.
Anyway i have a geometry where a smaller cylinder is connected to a larger diameter cylinder. I just used the normal blocking methods introduced in the tutorials as well as o-grid creation.
I've managed to create a mesh but it seems like the junction between the pipes the mesh cells directions dont look "in-line" i.e. they are angled. Is this ok or is there another way to block this geometry more effectively to avoid this?
Leepox is offline   Reply With Quote
Old   November 21, 2011, 03:22
Michal
Twix is on a distinguished road
You can generate blocking on larger cylinder, then create two o-grids and extrude faces to create blocking on smaller cylinder. Check this thread: http://www.cfd-online.com/Forums/ans...weep-mesh.html , the geometry is quite similar.
Regards
Twix is offline   Reply With Quote
Old   November 21, 2011, 10:32
Originally Posted by Twix View Post
Regards
thanks a lot for this! Definitely shows how inexperienced I am.
[ICEM] O-grid around wing geometry Anorky ANSYS Meshing & Geometry 15 November 27, 2017 13:43
[ICEM] Is it possible to blocking and mesh part of geometry? zhaohui ANSYS Meshing & Geometry 5 March 25, 2016 05:12
[ICEM] Blocking and Symmetry BrolY ANSYS Meshing & Geometry 32 August 24, 2012 03:13
[ICEM] blocking a seal geometry in ICEM HEXA Chilli ANSYS Meshing & Geometry 1 October 21, 2011 02:28
Problem in Initializing Blocking for 2d geometry nitin Dewangan CFX 6 October 24, 2008 01:03
