[DesignModeler] Design of catalytin converter
Old   November 18, 2011, 16:20
Default Design of catalytin converter
Sabrina
Sabrinache is on a distinguished road
I am trying to design a catalytic converter which is a porous W-shaped in a square channel. So, I connected each part as a solid extrude with adding material and for square channel, I have connected as a surface body as solid. For fluid, I have used same dimension as surface body but by extruding as frozen. But how can I joint all the separated solid part of W ??? When I mention extrude as add material, are they already connected at junction? And also if I am not right, please give me advice.
Sabrinache is offline   Reply With Quote
Old   December 14, 2011, 03:28
Graham81 is on a distinguished road
Extrude everything by "add frozen", then use Boolean-unite.
Graham81 is offline   Reply With Quote
[Other] Connecting 3D bodies in Ansys Design Modeler chipper ANSYS Meshing & Geometry 4 January 25, 2018 09:45
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 19, 2015 23:40
JOB: Sr. Thermal/Mechanical Design Engineer Dee Dee Dial Main CFD Forum 0 April 1, 2003 18:49
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
CFD - Trends and Perspectives Jonas Larsson Main CFD Forum 16 August 7, 1998 16:27
