[GAMBIT] One way valve geometry GAMBIT
Old   November 30, 2011, 08:42
Default One way valve geometry GAMBIT
Efthymios Efthymiou
ftimis is on a distinguished road
Can anyone help me to design one way valve geometry in gambit? Actually I am currently studying an unsteady flow through a pipe (after water exits pump) and I want to see the effect of adding an one-way-valve (known also as check valve) into the pipe.
ftimis is offline   Reply With Quote
Old   November 30, 2011, 08:46
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Do you have a sketch of your valve?
Already built within CAD maybe?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   November 30, 2011, 08:49
Efthymios Efthymiou
Actually not. I am very new in CFD analysis and I don't know so many things. Do I have to make a CAD first and then try to design geometry in Gambit?
Old   November 30, 2011, 08:53
-mAx-'s Avatar
Maxime Perelli
not necessary.
Prior to CFD analysis, you need to built your geometry (cad package or gambit).
Once you know your design, I will help you
Old   November 30, 2011, 08:54
Efthymios Efthymiou
Ok max. I will provide you with my design as soon as I have it. Thank you!
Old   December 5, 2011, 09:23
Efthymios Efthymiou
Originally Posted by -mAx- View Post
not necessary.
Hi max I am lost. I found some check valves design in youtube (links below). I can use either of them to make a start. I am currently working on the flow of the water in pipe (after exits water pump). I have already designed and analyzed an unsteady flow in a 2-d pipe and now I want to attach one-way-valve geometry in this pipe to see the difference in the flow of the water ( i am interested in the change of flow rate over time). Hope that I am clear and you can help me.
http://www.youtube.com/watch?v=aOOdW...eature=related
http://www.youtube.com/watch?v=qi7rh...B06A3A816195D1
Old   December 5, 2011, 10:34
Efthymios Efthymiou
http://www.youtube.com/watch?v=ehDd4...eature=related
Something like this I think is the easiest way. Can I create that in 2-d?
Old   December 5, 2011, 11:53
Efthymios Efthymiou
Old   December 5, 2011, 12:01
-mAx-'s Avatar
Maxime Perelli
static ou moving mesh?
Old   December 5, 2011, 12:04
Efthymios Efthymiou
what is the difference? (sorry for the idiot questions)
Old   December 5, 2011, 12:09
Efthymios Efthymiou
The straight pipe that I had design is created by 4 vertices ((0,0,0), (8,0,0), (0,0.05,0), (8,0.05,0)). I connected those vertices and created 4 edges. The boundary conditions are (velocity inlet, wall, pressure outlet and axis). Analyze in fluent 6.3 an axissymetric unsteady flow. Now I want to attach one-way-valve in this pipe to see the difference. Do I have to design a different pipe or just attach the valve in the existing one?
Old   December 5, 2011, 12:10
-mAx-'s Avatar
Maxime Perelli
the ball may rotate and it will open/close the valve.
Try first static mesh (one position (ball-angle))
Old   December 5, 2011, 12:17
Efthymios Efthymiou
Can this be done in 2-D?
Old   December 5, 2011, 12:33
-mAx-'s Avatar
Maxime Perelli
yes but not in 2d-axisymmetric
Old   December 5, 2011, 12:45
Efthymios Efthymiou
How should I proceed? Shall I just put a ball in the pipe and change the boundary conditions? Or I have to create a very different geometry?
Old   December 5, 2011, 12:53
-mAx-'s Avatar
Maxime Perelli
sketch first on paper, and post here
Old   December 5, 2011, 13:22
Efthymios Efthymiou
here is the sketch. I hope that is clear and I will be able to create one of these geometries.
Old   December 6, 2011, 00:49
-mAx-'s Avatar
Maxime Perelli
In fact I expected a sketch with dimensions
create turbine geometry with gambit badlaine ANSYS Meshing & Geometry 2 March 26, 2012 23:54
What can I employ to create geometry besides Gambit? summer ANSYS Meshing & Geometry 2 February 11, 2011 14:50
How to construct complex 3D geometry using GAMBIT? Feng FLUENT 5 October 11, 2005 04:13
problem about Importing geometry in Gambit Hua Gu FLUENT 3 April 2, 2002 14:24
Creating a Geometry in GAMBIT Sridhar FLUENT 2 November 26, 2001 10:11
