[ICEM] Help varying mesh densities
Old   December 2, 2011, 14:14
Default Help varying mesh densities
Hardeep
Hardeep is on a distinguished road
Hi guys I'm relatively new to CFD, having just started a few months back for a university project.
I'm using ICEM to mesh an aneurysm model and i want to set 2 different mesh densities in 2 different regions (aneurysm body and inlet extension). I set the global max element size to the size i would like in the coarser region (inlet extension) and then set a smaller max size for all parts in the finer region (aneurysm body) using the part mesh set up.
But when the mesh generates, while having the desired density at the surface, it still produces large elements inside the finer aneurysm volume corresponding to the global size, and not the one i set for it in the part mesh set up!
What am i doing wrong??
Thank you for any help you can give
Hardeep is offline   Reply With Quote
Old   December 2, 2011, 14:23
Hardeep
Or is there another way to have 2 densities/max element sizes in 2 different volumes?...
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
