December 11, 2011, 14:25 |
multibody
BaBa-Firat
Rep Power: 15 |
Hi ;
I am trying to mesh 2 bodies. These two bodies have 5 parts also. I do not want to combine 2 bodies into one because mesihng geometry with two bodies is easier. But I have some problem. When I import mesh intofluent, there is a boundary condition which is assigned as wall but I want this BC to be interior. In addition, these wall is between two fluid regions so there seems to be no problem in changing to interior but I can not!!! Please help me otherwise I will be dismissed with my ms thesis. With Regards |
December 12, 2011, 12:21 |
PS
Rep Power: 14 |
The interior bc is for a volume, not a face, which is what a wall bc is. I think you need an interface between the two fluids on either side of the "wall".
December 14, 2011, 00:59 |
BaBa-Firat
Rep Power: 15 |
thanks for your help
December 14, 2011, 18:12 |
Kevin Van Looveren
Rep Power: 14 |
I'm having the same issue (posted it in fluent subfolder)
But with the addition that I cannot select Interface. It's formed a boundary together with the mirrored version and i can only select: *fan *interior *porous-jump *radiator *wall |
December 15, 2011, 13:51 |
BaBa-Firat
Rep Power: 15 |
i could not find any solution so i had to left that problem
December 15, 2011, 14:28 |
meshing multizone
BaBa-Firat
Rep Power: 15 |
Hi
I am trayinh to mesh a geometry using multizone meshing method. Firstly I am meshing geometry which is sweepable so I get a hex mesh. Then I continue with second body with multizone method. But when it creates mesh for second body, it removes the mesh generated at first body. Does any body knows the reason? |
[Other] Connecting 3D bodies in Ansys Design Modeler | chipper | ANSYS Meshing & Geometry | 4 | January 25, 2018 09:45 |
[ANSYS Meshing] Hex meshing producing poor quality elements on multibody part | aarvay | ANSYS Meshing & Geometry | 8 | March 16, 2012 15:29 |
Imersed Multibody Dynamics | dandalf | OpenFOAM | 1 | March 30, 2011 08:24 |
How to merge bodies | Oxmox | ANSYS Meshing & Geometry | 4 | August 20, 2010 04:21 |
Connections of edges and faces between bodies (Workbench v12) | gexiste | ANSYS Meshing & Geometry | 2 | April 29, 2010 16:57 |
