[ICEM] How to export points from ICEM to Fluent |
December 12, 2011, 09:57 |
Philipp
Rep Power: 26 |
Dear All,
I made a 3d mesh of a pipe in ICEM and want to track some point values via "monitors" in Fluent. Now I created points in ICEM and put each of them into a "part" with a different name. Back in Fluent none of these points appear in any "surfaces" box. How can I get single points from ICEM to fluent? Thanks for any help! |
April 23, 2012, 13:05 |
#2 | |
Justin Flanders
April 23, 2012, 13:57 |
Ghazlani M. Ali
Rep Power: 29 |
It's impossible to do that. Fluent won't read your points and curves. i tried before with a curve. i got help from Mr simon who forwarded my problem to a fluent expert.
See the thread below http://www.cfd-online.com/Forums/ans...eate-icem.html |
April 23, 2012, 14:59 |
#4 | |
However you cannot export the point and curves (3d) from ICEM to Fluent |
February 26, 2014, 15:59 |
export point workaround
Grant
I recently had to export a large set (100+) of geometry points from ICEM. A workaround that I found is to:
1) clear the log window 2)Use the point locator button (in the top toolbar) to select each point you want the coordinates for 3) the coordinates for each point show up in the log window as you click them. When you're done, save the log window to a file |
December 20, 2017, 04:13 |
Extract Points from ICEM CFD
#6 | |
Vishwas Verma
Rep Power: 10 |
Another quick way is to put, points in a dummy part and save tin file. Open tin file in text editor, you will see lines like "prescribed_point x y z family dummy part name point number". Copy paste all points you want in excel and remove unwanted columns.
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 03:34 |
Cannot import ANY ICEM hex core into Fluent v6.3!! | Robert Perry | FLUENT | 11 | April 12, 2012 04:30 |
Export mesh from ICEM to Fluent 6.3 (3D) | bigbang | ANSYS | 0 | June 7, 2010 23:05 |
[ICEM] 2D mesh export to FLUENT | Ed Kay | ANSYS Meshing & Geometry | 0 | October 22, 2009 11:08 |
Exporting Meshes from ICEM to Fluent | zi | FLUENT | 4 | August 9, 2005 10:58 |
