[ICEM] Geometry Tolerance and meshing
Old   May 26, 2011, 17:01
Default Geometry Tolerance and meshing
Claudio
Mitpostdoc is on a distinguished road
Hello there.
I worked for the past 2 months on the meshing of a very complex centrifugal compressor. After many days of frustration with Icem I managed to have a clean and smooth structured mesh of the geometry. However, whenever I try to refine it, I have negative determinants everywhere .
I am trying to do a CFD simulation of a high pressure compressor with supercritical CO2. The Re is very high and the estimated cell size in order to have a reasonable y+ near the wall is between 1 and 0.1 microns .
I tried to repair the geometry several times with icem, but even if I set the model tolerance and triangulation tolerance to 10^-07 I still can not fix it. Moreover, since Icem lacks of proper methods to define periodic planes, I had to manually crate all the periodic boundaries. Needless to say that all the geometric entities I created share the same tolerance of the geometry.
Is there anybody who can help me? Does anybody have any experience with this kind of issue?
thanks
Mitpostdoc is offline   Reply With Quote
Old   June 6, 2011, 07:34
jeevan kumar
jeevankumarb is on a distinguished road
If you can upload the tetin and the blocking file then i will have a look and can suggest you.
regards
jeevan
jeevankumarb is offline   Reply With Quote
Old   June 6, 2011, 09:33
seaharrier is on a distinguished road
why don't you use turbogrid to mesh your compressor?
seaharrier is offline   Reply With Quote
Old   June 6, 2011, 10:03
Claudio
Hello there!!!
Thank you very much for the reply.
Unfortunately I am not allowed to disclose any of the geometry file as they belong to the industrial sponsor . Very sad, I know. Is there any way I can provide some information without giving up rights on the geometry file? In particular, I was trying to generate planes and lines in Icem. Even if I specify very small tolerance I can still see that lines and surfaces are not perfectly matching. Even if I keep tolerance to 10e-07 I can't refine the mesh to 10e-06 without having cells falling into the gaps.
I actually thought about Turbogrid... but I am not sure how I can generate the initial file to be imported: The geometry I am working on is fairly complicated with seal passages and leakage flows. I have a STEP and parasolid file of the whole geometry. How do I generate the initial file to be imported in Turbogrid?
Thanks a lot for your help!!!
Old   January 1, 2012, 12:51
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
got any solution?
Far is offline   Reply With Quote
Importing CAD geometry and Editing edges to match Ahmed CFX 15 March 21, 2016 12:39
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
stitchMesh for uncongruent patches (stitch tolerance) beugold OpenFOAM 0 June 18, 2009 07:38
ICEM: Holes in Geometry Daniel CFX 4 February 22, 2009 09:40
GAMBIT - warn about geometric tolerance CFDNewbie FLUENT 2 July 7, 2007 09:48
