[DesignModeler] problem with importing solidworks model |
May 31, 2012, 17:27 |
ARUN V
Rep Power: 13 |
Hi all....As a part of a project i need to do a CFD analysis on a formula car. Firstly i want to do the CFD of the raw chassis
I cant import a solidworks model of a roll cage.It shows an error symbol when i click generate.... Uploaded with ImageShack.us I use ANSYS Fluent v13. The roll cage consists of many solid (non hollow) rods. Also, the roll cage is surrounded by thickened, mirrored surfaces(lofted).without this exterior panelling i can import the model though i face problems in later stages I am new to this software as i went through some tutorials last week.. I would be grateful if you could reply ASAP.... Last edited by a_run_91; June 1, 2012 at 11:34. Reason: adding some more details to the question |
June 1, 2012, 01:06 |
Andrey
Rep Power: 16 |
May be errors in the geometry or in the path to the file. Attach SolidWorks file.
June 1, 2012, 12:05 |
#4 | |
ARUN V
Rep Power: 13 |
I checked for errors in geometry and the path....but i couldnt find any. I attached solid works file as you said.... But the model was successfully imported after removing the exterior paneling...Actually i want to do the CFD of the this exterior... |
June 1, 2012, 16:12 |
ARUN V
Rep Power: 13 |
Hi Ali...
Thanks for your reply.. I tried doing that..but after doing " file >>save as>>change save as type to IGES>>ok " The solid works crashes and that saved document is not found...But this conversion works for the model without any panelling.... This external thickened surface is causing all sorts of problems...I had problems with solid works in thickening and mirroring lofted surfaces..but some how i made one model surface and now i cant analyse it.... ;( |
June 4, 2012, 04:54 |
Hello, I don't know the geometry you are studying but Save as IGES always works for me.
You may already did it but when you save as IGES check the Export Options. There is a surface representation/system preference for ANSYS. Changing this and other preferences could help you with the import problem.
-- Kyriakos Vafiadis Mechanical Engineer, PhD candidate |
designmodeler, import, importing, solidworks model |
Importing Rhinoceros 3d model to SolidWorks | george85 | FloEFD, FloWorks & FloTHERM | 21 | March 5, 2014 05:19 |
export 2d model from solidworks to gambit | bad080boy | Main CFD Forum | 2 | April 29, 2011 14:31 |
Problem in Buoyancy Model? | dhrubo | CFX | 3 | June 5, 2010 05:32 |
Polyflow Simulation with ViscoElastic Model memory problem | sid2909 | FLUENT | 0 | May 10, 2010 05:29 |
