[ICEM] O-grid to shape the fillet of a turbine |
January 23, 2012, 04:15 |
Christoph
Rep Power: 17 |
Hi guys,
i have some serious problems with the fillets of my turbine (<90°). I've tried to shape the fillet with an o-grid several times , but without any success. I've attached some pics. Which blocks and which faces do i have to choose to create the blocking on pic 4 (blocking_fillet)? Last two pics shows the blocking and scan plane from a similar turbine. Thx in advance. Last edited by energy382; January 25, 2012 at 08:43. |
January 26, 2012, 02:58 |
Christoph
Rep Power: 17 |
Still not solved my problems at hub/blade (fillet) and gap (between leading edge and heatshield). Could anyone please help me?
I become desperate. I tried it several times without success. Again: i need an o-grid to resolve the fillet between hub and blade and I didn't get managed to block the gap ( maybe the edges of the o-grid in front of the leading edge were not associated in the correct way to the heatshield/stator). I would be glad to have your help in blocking or just an explanation. Thx guys. Blocking and tin-files: http://www.file-upload.net/download-...1/cfd.zip.html Finally fixed all problems! Premesh looks very nice now. I will make a detailed report with some pics at the weekend for those, how has similar problems (geometry). Last edited by energy382; January 26, 2012 at 12:25. |
January 27, 2012, 03:27 |
did you make new surfaces and curves where you made the associations, coz when I checked your files , I noticed similar problem, and I am wondering where would you associate the edges?
1 more thing, why did you make the two edges in the tip gap and how did you do it? |
January 31, 2012, 12:09 |
Christoph
Rep Power: 17 |
Hey!
sorry, it takes me a time to answer your question. With the two edges in the tip gap I created an GGI (nodes didn't match there as you can see). I've splitted vertices and then associated them to the curve. That's the way i made the interface in the middle of the tip. |
January 31, 2012, 12:35 |
#6 | ||
Could you explain it bit more, as it is closely related to my field of interest and you have done a fantastic job. |
February 13, 2012, 05:05 |
Christoph
Rep Power: 17 |
sorry, took me a while to answer your question. I made some screenshots to show, how i made the grid interface on the tip. I hope it's comprehensible.
February 13, 2012, 05:06 |
Christoph
Rep Power: 17 |
last screenshot
Obtain Geometry Data from a Grid File in CFX 10.0 | ARJUN | CFX | 2 | August 17, 2006 07:20 |
turbine noise | naser | FLUENT | 0 | December 3, 2004 13:37 |
Grid Independent Solution | Hesham M. Aly | FLUENT | 2 | October 5, 2000 08:24 |
Troubles modelling flow through a grid | Hans Klaufus | CFX | 1 | June 28, 2000 16:43 |
Grid Independent Solution | Chuck Leakeas | Main CFD Forum | 2 | May 26, 2000 11:18 |
