[ANSYS Meshing] Mesh around a rotating cylinder
Old   March 10, 2012, 13:58
Question Mesh around a rotating cylinder
Leandro
leomec88 is on a distinguished road
Hello guys!!
I am a new CFX user and I have been working in a air flow over a rotating cylinder simulation. I know that in this type of simulation, the boundary layier is really relevant. So, because of this, I have been workin really hard trying to improve my mesh around the cylinder. I found one interesting paper about this type of simulation that shows the attached picture. The picture shows the mesh I'm trying to do. But, i have lots of difficult to implement that. I would like to know if somebody can help me to do that mesh ( not exactly that ond..but close). Can somebody tell me the steps I should follow to create such mesh? I am using the workbench and I will simulate in CFX. I have created a thin plate with a small hole (cylinder) in the middle. So now, how should I proceed?
Thanks!!
leomec88 is offline   Reply With Quote
Old   March 11, 2012, 00:17
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
I have no idea about the AM, but can be easily done in ICEM. http://www.cfd-online.com/Forums/ans...cylinders.html tin and blocking files are also attached with post for cylinder of 1 dia.
Far is offline   Reply With Quote
Old   March 11, 2012, 03:10
Far
Sijal
This might be required method you are looking for in AM and DM https://confluence.cornell.edu/displ...+Specification
Old   March 11, 2012, 07:37
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Right, if you want a mesh with this sort of topology, ICEM CFD is easier. But you could still do it in ANSYS Meshing... Just subdivide the plate into each of those regions and map each face... But I don't recomend that...
If I were doing this in AMP for CFX, I would just use the sweep mesher (or the multizone mesher). It will use a more unstructured mesh on the surface and sweep it thru the thickness of the plate... That type of mesh can actually be more efficient in some cases because the unstructured mesh can transition to larger sizes...
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   March 11, 2012, 14:58
Leandro
Thanks for the answer guys! I'm going to try the advices!
3-d mesh gambit (cylinder within a cylinder) Jason ANSYS Meshing & Geometry 29 October 30, 2015 08:59
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
Rotating cylinder raul FLUENT 3 February 1, 2015 05:48
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
