[ICEM] Blocking strategies for eight little holes
Old   March 22, 2012, 14:00
Question Blocking strategies for eight little holes
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
hello everyone, i'm back again with my air intake
I managed to mesh the back part along with the inside of the air intake (picture 1), however i still need to deal with eight little holes shown in picture number 2.
I have a question: is there a simple way to take care of the eight holes on top of the block number 7 (picture 3). i guess the basic way to do that is to split the block 7 into eight small block, extrude and associate the edges ? is there another way ? just for trying i started by creating a new block (number 124 in the picture) that i will try to merge with number 7, is it possible to do that ? Thank you for you help in advance
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   March 22, 2012, 14:28
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
That's the method, you have already figured it out. Use o block for each 7 holes (Edit: Apply O-block for eight holes). Check this out http://www.youtube.com/watch?v=KabKF...eature=related
Far is offline   Reply With Quote
Old   March 22, 2012, 15:00
Far
Sijal
If you can attach the tin and blk (on forum or through pm), then I can suggest you something.
Old   March 22, 2012, 23:00
Far
Sijal
Main Command: Extrude along curve (provide appropriate face, one curve from starting surface to ending surface, end point of that curve). split should run across all blocks (vertically) for efficient use of o block
Old   March 24, 2012, 08:11
diamondx's Avatar
Ghazlani M. Ali
what i would have done to control to blocking is adding surfaces at the ends of each hole so that the premesh can appear beautiful. if i don't add surfaces, the faces of the top projects on the faces in the bottom making it very messy. when i add surface -> update blocking -> premesh , everything look fine. i'm sure that my association are corrects. did you get my problem ?
Regards,
Ali
Old   March 24, 2012, 10:05
Far
Sijal
No, I didn't get the problem.
Old   March 24, 2012, 10:47
Far
Sijal
Oh yes, You are 100% correct. I didn't check the premesh, just created blocking. So when turned on the premesh, I get the mess and after adding the ending surfaces mesh is OK as it should be.
I have observed another thing, that is the vertical edges of extruded blocks are not parallel to each other, however the edges on circle are parallel to all extruded blocks. I didn't understand this philosophy of blocking. Please note that I am talking about the when I turn on option of copy mesh parameters to all parallel edges.
[ICEM] Blocking and Symmetry BrolY ANSYS Meshing & Geometry 32 August 24, 2012 03:13
[ICEM] Using Blocking with ICEM (infinite blocking lines appeared) Touré ANSYS Meshing & Geometry 2 August 5, 2012 17:27
[ICEM] Blocking topo for hexagonal tube with holes siw ANSYS Meshing & Geometry 3 February 10, 2012 14:17
How to set up meshes of sparse and small holes? leeyee FLOW-3D 1 September 2, 2010 22:50
Flow through multiple holes Matthew Markham Main CFD Forum 3 January 28, 2009 21:47
