/tmp related problem with installing ANSYS CFX 13 |
August 11, 2012, 17:38 |
Juan Marcelo Gimenez
I am trying to install ANSYS CFX v13 in ubuntu12.04 64bits. When I begin the installation process I get this error: Code:
$ sudo ./INSTALL copying necessary files to /tmp/ans_install_tmp4465/ Executing /tmp/ans_install_tmp4465/instcore /tmp/ans_install_tmp4465/INSTALL: 83: /tmp/ans_install_tmp4465/INSTALL: /tmp/ans_install_tmp4465/instcore: not found I tried again as root and still got the same error. The script seems can not copy the folder of the dvd called "instcore" into /tmp folder. I updated my ubuntu version and this error stills. When I tried in other machine (ubuntu 10.10 64 bits) the installation started without problems (a graphical interface opened). Is any problem with graphical libraries as mesa? I also installed all requeried mesa packages. Any help will be much appreciated. |
October 25, 2012, 02:35 |
32bit libraries
I just tried to install ansys13 to a fresh install of Ubuntu 12.10, 64bit version.
The error is due to to Ubuntu not having libraries for 32bit executables (the installer is 32bit) by default. Unfortunately the error messages (not Ansys fault) are really obtuse. You can install the necessary libraries with the following: sudo apt-get install ia32-libs |
October 25, 2012, 11:54 |
Thank you slug! those were libraries needed!
Finally, I could install successfully ansys13. Greetings |
ansys, fluent, instcode, ubuntu 12.04 |
Setting Pressure Boundary Conditions in ANSYS CFX Pre | saisanthoshm88 | CFX | 21 | February 22, 2017 16:50 |
[ICEM] issue occur after extrude 2D airfoil mesh and convergence problem in CFX | shiyun | ANSYS Meshing & Geometry | 4 | May 9, 2012 19:55 |
ERROR #002100056 CFX FSI problem | Hongdao | CFX | 0 | November 10, 2010 03:58 |
CFX Casting problem: Can it be done all in one? | jfasl | CFX | 1 | September 14, 2010 03:14 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
