September 15, 2012, 16:56 |
Editing expressions from the command line
Rep Power: 14 |
I want to run some parametric tests. It is a simple problem, with two parameters which are defined as expressions that I want to change. I have around three hundred combinations of the parameters to run, so I don't fancy doing it manually. Is there a way I can run a .def file from the command line multiple times with cfxsolve , but edit the expression values? Thanks |
September 21, 2012, 10:15 |
Sascha
Rep Power: 14 |
Hey Hemo,
unfortunately I am not able to help you with your question exactly. But wouldn't it be easier ( if possible) to run everything within the Workbench using Design Points ? This would pretty much cover your Parameter Analysis and you wouldn't have to write many lines of script. Greetings |
September 21, 2012, 10:33 |
Rep Power: 14 |
Hi Sascha,
Thanks for the suggestion. In the end, I exported the ccl and edited it in matlab, then ran everything from the command line. |
Specify hybrid values for expressions in CFX-Post? | jtipton2 | CFX | 2 | July 20, 2013 03:58 |
Average of Expressions in Transient Run for Parameter Study | BigPapi34 | CFX | 1 | August 7, 2012 05:34 |
Grouping expressions in CEL | foo7 | CFX | 4 | September 21, 2011 09:15 |
Orbital velocity Inlet expressions | rc2v07 | CFX | 6 | July 11, 2008 14:21 |
Cel expressions for trasient problem | Jervds | CFX | 0 | March 4, 2008 10:03 |
