September 19, 2012, 23:54 |
Fluent error
jbr
Rep Power: 14 |
Dot product of flow direction and area normal is zero.
Check the specified flow direction on Mass Flow Inlet boundary conditions for thread 8..this was the error i m getting when i m trying to simulate flow of the air in a room to find temperature and velocity profiles.i m new to this software and if its a amateur question..please bear with me |
September 25, 2012, 11:48 |
Alex
Rep Power: 47 |
A dot product of zero between the face normal vector and the flow vector indicates that they are orthogonal. This way, no flow can enter the domain at this boundary.
Verify the direction vector of your boundary condition and make sure it has a component pointing towards the surface normal vector. I guess you just confused x and y components of the velocity vector. |
September 29, 2012, 20:07 |
jbr
Rep Power: 14 |
thanks there
May 15, 2020, 16:53 |
#4 | |
Rep Power: 6 |
November 27, 2022, 16:03 |
backdoor
Michal Pecz
Rep Power: 3 |
Why cant really programs have at least the most basic backdoor?
And why is mass flow not defaultly prependicular to surface. One writes value and vuala this junk cant eve crash properly. It just gets stuck and have to be manually killed via procesess. |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 04:53 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Accessing phi from a fvPatchField at same patch | johndeas | OpenFOAM | 1 | September 13, 2010 20:23 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
[Netgen] Installation of Netgen in SuSE Linux 92 | edvardsenpriv | OpenFOAM Meshing & Mesh Conversion | 23 | January 16, 2009 06:12 |
