#21 |
Rep Power: 8 ![]() |
I am want PhD work on IC engine (SI engine) analysis.
I am quite new to Fluent. I did some basic things using mixing of fluids etc. But I can't get any for mixing to fuel or more tutorials for IC engine combustion etc. I want to analyze The flow and combustion in IC engine using different new fuel. Can anyone help me with above. anyone have some good tutorial for this? Thanks. upendrarajak86@gmail.com |
#22 |
pramod
Rep Power: 0 ![]() |
#23 |
Kurtulus Polat
hi everyone,
1.Cold Flow Simulation:- files (demo_eng.x_t and lift.prof) 2.Port Flow Simulation:- file (tut_port.x_t) 3.Combustion Simulation for a Sector:- files (tut_comb_sect.x_t, injection-profile, Diesel_1comp_35sp_chem.inp, and Diesel_1comp_35sp_therm.dat) 4.Gasoline Direct Injection Engine Simulation:- files (tut_gdi_comb.x_t, comb_lift.prof, footprint.txt, massflowrate.csv, and velocity-0.7cd.csv) can someone send to me this folders? kurtuluspolat01@gmail.com |
#24 |
CHN-CHI-CHING
hi everyone,
1.Cold Flow Simulation:- files (demo_eng.x_t and lift.prof)(it can be download) 2.Port Flow Simulation:- file (tut_port.x_t)(it can be download) 3.Combustion Simulation for a Sector:- files (tut_comb_sect.x_t, injection-profile, Diesel_1comp_35sp_chem.inp, and Diesel_1comp_35sp_therm.dat) this case can't not download both of following ( Diesel_1comp_35sp_chem.inp, and Diesel_1comp_35sp_therm.dat) did anyone had it ? if you had please upload... 4.Gasoline Direct Injection Engine Simulation:- files (tut_gdi_comb.x_t, comb_lift.prof, footprint.txt, massflowrate.csv, and velocity-0.7cd.csv) this case can't not download following ( footprint.txt, massflowrate.csv, and velocity-0.7cd.csv) did anyone had it ? if you had please upload... can someone send to me ? thanks m10411030@yuntech.org.tw |
#25 |
ahmed imad abbood
Hi guys
I have real problem with IC engine (forte) 18.1 . In geometry step when I click on Generate appear this error ((Symmetry direction is not correct .Symmetry plane should aligned with x-z plane , the geometry should lie in the y-positive half space)). Any one can help me please ??? |
#26 |
Sabari Ganesh
#27 |
Please send me the tut_port.x_t file.
arashmd538@gmail.com |
#28 | |
BIBU B
Rep Power: 7 ![]() |
bibhubjohn@gmail.com |
#29 | |
BIBU B
cfd-offline is not active please sent me that files in bibhubjohn@gmail.com please sent me a winrar file |
#30 | |
Lagos
I will greatly appreciate your kind gesture |
#31 |
ahmed imad abbood
#32 |
Hi every one please help me.................
how to fuel properties change for diesel engine other than fluent data base. like biodiesel............any suggestion me and send me demo file upendrarajak86@gmail.com |
#33 |
sanjay sajeevan
excuse me, do you have those files now with you?
#34 |
sanjay sajeevan
excuse me, the link is not working.
#35 | |
Gusma
my email putragusmahamdana@yahoo.com. |
#36 | |
saliha blkb
I too need these files(tut_comb_sect.x_t, injection-profile, Diesel_1comp_35sp_chem.inp, and Diesel_1comp_35sp_therm.dat), can u mail them to me at climatiquegni@gmail.com. Thanks in advance. |
#37 |
VIC
i have ANSYS Internal Combustion Engines Tutorial
Guide in Workbench.pdf , in which consist of 4 different examples ..... and but i dot have the related files to perform these simulation 1.Cold Flow Simulation:- files (demo_eng.x_t and lift.prof) 2.Port Flow Simulation:- file (tut_port.x_t) 3.Combustion Simulation for a Sector:- files (tut_comb_sect.x_t, injection-profile, Diesel_1comp_35sp_chem.inp, and Diesel_1comp_35sp_therm.dat) 4.Gasoline Direct Injection Engine Simulation:- files (tut_gdi_comb.x_t, comb_lift.prof, footprint.txt, massflowrate.csv, and velocity-0.7cd.csv) Please if any body does have this file can you send me the links or mail me at whmgr.gr@gmail.com |
#38 |
kc yong
Guide in Workbench.pdf , in which consist of 4 different examples ..... and but i dot have the related files to perform these simulation 1.Cold Flow Simulation:- files (demo_eng.x_t and lift.prof) 2.Port Flow Simulation:- file (tut_port.x_t) 3.Combustion Simulation for a Sector:- files (tut_comb_sect.x_t, injection-profile, Diesel_1comp_35sp_chem.inp, and Diesel_1comp_35sp_therm.dat) 4.Gasoline Direct Injection Engine Simulation:- files (tut_gdi_comb.x_t, comb_lift.prof, footprint.txt, massflowrate.csv, and velocity-0.7cd.csv) Please if any body does have this file can you send me the links or mail me at kahchun96@gmail.com |
#39 |
emirhan
Hi, can you sent me files please it is not available
1.Cold Flow Simulation:- files (demo_eng.x_t and lift.prof) 2.Port Flow Simulation:- file (tut_port.x_t) 3.Combustion Simulation for a Sector:- files (tut_comb_sect.x_t, injection-profile, Diesel_1comp_35sp_chem.inp, and Diesel_1comp_35sp_therm.dat) 4.Gasoline Direct Injection Engine Simulation:- files (tut_gdi_comb.x_t, comb_lift.prof, footprint.txt, massflowrate.csv, and velocity-0.7cd.csv) Please if any body does have this file can you send me the links or mail me at emrhn_grn@hotmail.com |
#40 |
YAMA CLOVIS MBENG
hi everyone, i also need this demo_eng.x_t and valve lift.prof for ansys 15.0,
can some help me with it via: clovis@glenswayy.com |
Display Modes | |
[DesignModeler] Geometry preparation for IC engine | sado | ANSYS Meshing & Geometry | 0 | November 6, 2012 15:49 |
Simplified engine simulation | lovecraft22 | OpenFOAM | 1 | April 14, 2012 07:18 |
CFD of combustion process of Homogeneous Charge Compression Engine (HCCI) | kelvinlim | Main CFD Forum | 2 | January 26, 2012 22:19 |
meshing of two-stroke engine in gambit | ravi | FLUENT | 2 | January 18, 2012 01:14 |
Need help for IC engine analysis in basic level | tsram90 | FLUENT | 0 | November 3, 2011 06:57 |
