Problem: Fluent axisym. in CFX Post areaAve
Old   March 20, 2013, 08:33
Default Problem: Fluent axisym. in CFX Post areaAve
Johannes Ringborn
j_h_86 is on a distinguished road
I did a a axisymmetric calculation in Fluent and want use CFX Post for postprocessing.
The contour plot of my surface shows a range of the local Nusselt number between 230 and 310. When I want to calculate the area averaged value, CFX returns a value in the order of 0.01, which can't be possible.
Is the problem in the axisymmetric problem, which can't be postprocessed with the function areaAve? BTW: Both the local and global Nusselt number are calculated correctly dimensionless.
Best regards
Local Nusselt Number= Wall Heat Flux/(Thermal Conductivity Air*(Temperature-293[K]))*Radius=230 - 310
MeanNusseltNumber=areaAve(Local Nusselt Number)@curve_disc_top=0.01
j_h_86 is offline   Reply With Quote
OpenFOAM vs. Fluent & CFX marco FLUENT 16 November 17, 2020 04:53
Alias problem when starting FLUENT from command line batch_error FLUENT 0 May 24, 2012 08:20
cfx post problem bharath CFX 2 August 4, 2008 11:59
Fluent and CFX Ale CFX 1 July 2, 2008 18:19
Fluent and CFX Ale FLUENT 0 July 1, 2008 08:36
