Ansys 3D mesh
Old   July 1, 2013, 09:17
Default Ansys 3D mesh
Giuseppe
Bepperux is on a distinguished road
Hi all,
Sorry for my ignorance, I'm just a beginner. I successfully used Ansys + Fluent in the study of a pipe with a sharped edge orifice, 2D case, similar to this picture: http://www.ara.bme.hu/~cfd/FLUENTkur...i/image008.jpg
However, now I have a problem for the 3D case. I designed my 3D valve in Solidworks, with its inner ducts, and I imported it into Ansys. In the 2D case, I had to name the edges of the "rectangle" (the pipe) to define the boundary conditions (wall, axis, inlet, outlet), and the surface was the domain to study, on which the mesh was applied.
How can I do the same for the 3D case? I don't know how to select the inner duct to indicate it as the domain to apply the mesh on, because it's...empty!! And also the surfaces as inlet and outlet ports.
Thank you everyone
Bepperux is offline   Reply With Quote
mesh valve 3d
[ANSYS Meshing] Extruding 2D mesh to 3D mesh in ANSYS meshing Rachit ANSYS Meshing & Geometry 10 February 14, 2024 08:19
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
Problem importing GAMBIT mesh to Ansys geometry David G. CFX 0 June 19, 2005 06:01
