Strange issue while launching ANSYS workbench in CentOS 6.4
Old   July 12, 2013, 17:48
Default Strange issue while launching ANSYS workbench in CentOS 6.4
Wei-Che Chiu
Philip_C is on a distinguished road
Hi all,
I am trying to launch the ANSYS workbench (14.5.7) in the CentOS 6.4 environment; however, it was not able to be launched successfully. I had no such issue while launch the workbench in the windows environment, and I was able to run individual program such as Fluent in Linux without any issue.
The ANSYS customer support suggested me to change the OS since CentOS was not supported by ANSYS (?); however, based on my understanding that CentOS is based on Red Hat (which is supported by ANSYS). Therefore I would like to know if anyone met the similar issue? and has anyone know how to resolve this issue?
Thanks,
Philip_C is offline   Reply With Quote
Old   July 12, 2013, 19:12
mjgraf is on a distinguished road
sure Support also said to follow the installation instructions?
you must follow the instructions in ai_instl.pdf "Ansys, Inc. Installation Guide for Linux" Chapter 2. Where it states to install or create symlinks, please verify before just doing their instructions. Use yum to check packages and verify the sym link before creating it.
there is a typo where libXp.x86_64 is listed twice, it should be .i686 for the second. So you need both.
If you follow the instructions, it should work. I have Workbench running on CentOS 6.3.
Programs listed in the intro and section, RHEL 6, Ansys Workbench, System Libraries.
Other sections can be performed as needed.
also the error reported would be nice. this typically says what library is missing.
mjgraf is offline   Reply With Quote
Old   July 12, 2013, 19:21
Wei-Che Chiu
Thanks, I have tried to install the library, but the same issue remained...
The error message was very long, and I past the last section of it:
Got a SIGSEGV while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
/ansys_inc/v145/Framework/bin/Linux64/runwb2: line 244: 8026 Aborted (core dumped) $MONO_PREFIX/bin/mono $WBII_ROOT/Framework/bin/$ARCH/AnsysFW.exe $WBIIINTARGS
Thanks,
Old   July 12, 2013, 19:23
you have gone through all the packages in that pdf?
Old   July 12, 2013, 19:42
Wei-Che Chiu
Yes, I have tried to update all the listed libraries, but the same issue remained...
The file asked me to install two patch, "kernel-2.6.32-71.14.1.el6.x86_64.rpm and kernel-devel-2.6.32-71.14.1.el6.x86_64.rpm", however, I was not able to find these two patches to install...
Sorry I am not very familiar with linux...
Really appreciate your helps
Old   July 12, 2013, 21:37
that is just the minimum kernel level. Is you have 6.4, you are running the latest.
to compare, just type
uname -a
in a command line.
Old   July 25, 2013, 15:40
Default after reading the manual
Allen Rueter
allen-cts is on a distinguished road
Philip-c ,
I had the same error
I finally got it to work by adding the -oglmesa switch
(down in chapter 8.3)
I have it running on Scientific Linux release 6.2
allen-cts is offline   Reply With Quote
Old   July 25, 2013, 15:54
Wei-Che Chiu
Hi allen-cts,
It finally works after months of frustration.
Thank you very much.
Old   July 25, 2013, 22:41
the mesa enables the software rendering.
just curious
if this is a linux workstation or are you remoting into it from a windows machine using a remote x11 like exceed?
Old   July 31, 2013, 03:18
Wei-Che Chiu
Hi mjgraf,
Sorry for the late response. I am using the linux work station.
Although I am able to launch the workbench successfully as in Windows; I am still having trouble to actually launch individual program such as DesignModeler...
Old   July 31, 2013, 09:39
could be a graphics card driver issue. what card is installed and are the drivers properly installed?
what do you get from a glxinfo
Only need to the top portion, no need for all the table info.
Old   August 29, 2013, 06:44
Sheng
micro11sl is on a distinguished road
The solution by allen-cts works for me! OS: Scientific 6.3
But DesignModeler can't startup. The status just hangs there. Any solutions?
micro11sl is offline   Reply With Quote
ansys, centos, redhat, workbench 14
Gambit vs. Ansys workbench mesh generating sanlee39 Main CFD Forum 2 April 8, 2013 06:09
Ansys Workbench - setting up batch processes sErik ANSYS 2 February 7, 2013 01:26
ansys workbench on linux zoe~~ FLUENT 7 January 17, 2013 23:02
Strange ANSYS Meshing 13.0 Problem brunob ANSYS Meshing & Geometry 3 June 21, 2011 20:03
Ansys workbench 12 and 12.1 ACER CFX 0 April 29, 2011 21:43
