Acoustic Analysis using Fluent and ANSYS mechanical
Old   November 10, 2013, 18:46
Exclamation Acoustic Analysis using Fluent and ANSYS mechanical
Ankit Tiwari
ankit1512 is on a distinguished road
Hi ,
My goal is to calculate the turbulence generated noise as well as the noise generated due to fluid structure interaction in a S-shaped pipe flow problem. Also ,I have to calculate the Sound Pressure level at 1 m outside the pipe due to the resultant noise.
I am facing problems in exporting the pressure data from transient flow solution of fluent to MAPDL/Harmonic analysis module in ANSYS workbench.
So, I calculated the Turbulence generated noise using broadband noise model. To calculate the fluid structure interaction noise,I first exported the fluid pressure into a Static structural analysis module with the same geometry,performed the static structural analysis. Then I exported the pressure and the stress data onto another Modal analysis module. ( I did so because I am unable to transfer data from Fluent to Modal analysis module).I got a range of 6 frequencies of vibration. I created a 2-D circular infinite acoustic model and used the highest frequency as source frequency at the centre of the domain.Then I calculated the sound pressure level at a distance of 1 m from the source.
Is my approach correct? The main confusion I have is whether to use modal or harmonic analysis for this purpose. Given below are the problem data :-
I am working on a simple S-shaped turbulent pipe flow problem. The pipe dia is 0.1 m and the S-section length is 200(m)-100(m)-200(m). The fluid is air and the pipe is made of steel. The inlet velocity is 10m/s.
Last edited by ankit1512; November 10, 2013 at 18:49. Reason: Better problem description
ankit1512 is offline   Reply With Quote
acoustic, acoustics, ansys workbench 14, fluent 14.5
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
Exporting fluent melting/solidification model results to ansys mechanical apdl omair11 ANSYS 3 August 28, 2013 06:22
Ansys mechanical APDL launcher license for Fluent mohammad FLUENT 0 June 30, 2011 01:09
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
Uncoupled analysis with FLUENT and ANSYS Mohammed FLUENT 0 September 13, 2006 12:41
