How to solve in ANSYS V12.1 model information problem.
Old   March 22, 2014, 17:36
Default How to solve in ANSYS V12.1 model information problem.
Ilker is on a distinguished road
Hi all,
I drew in ANSYS V12.1 a simple geometry. I completed drawing and then I made the mesh. While I was making the mesh I created five different regions (boundaries) and named these regions respectively. I completed making the mesh and then while I opened the "Setup" section I met "The model information is not compatible with the mesh" failure. I attached the the file to clearify and to identify the problew which I met when I opened the Setup section in ANSYS V12.1.
Does anybody has any information to solve "the model information is not compatible with the mesh" problem? I will be very pleasure for your helps.
Thanks for your attention and for your helps.
File Type: jpg Modelinformationfileisnotcompatiblewithmesh_failure.jpg (101.0 KB, 1 views)
Ilker is offline   Reply With Quote
Old   March 22, 2014, 20:32
I have investigated for a long time to solve this problem. If anybody has any idea how to solve or fix this proble would anybody like to share?
Thanks a lot for your attention.
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 05:52
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
How to use non-equilibrium thermal model for porous medium in Ansys CFX 13.0? Chander CFX 3 November 28, 2011 14:26
Problem in Buoyancy Model? dhrubo CFX 3 June 5, 2010 05:32
extremely simple problem... can you solve it properly? Mikhail Main CFD Forum 40 September 9, 1999 09:11
