Regarding exporting user defined range of value from CFD post to excel
Old   April 12, 2014, 09:56
Default Regarding exporting user defined range of value from CFD post to excel
ijaz fazil
er_ijaz is on a distinguished road
Hi
I have run a simulation and found velocity on the plane. Global range is very high. So I just defined the range between 0 to 8 m/s. Now I need to export these datas to excel sheet. When I export I can select only the variable, but I couldn't able to select the range. What Shall I do to select the range.(Global range is between -20 m/s to 30 m/s). But I need only 0 to 8 m/s.
er_ijaz is offline   Reply With Quote
cfd post, excel, fluent 14.5
[ANSYS Meshing] Displaying solid domains in CFD Post without meshing them. hda ANSYS Meshing & Geometry 5 October 24, 2016 09:26
Parallel process & CFD POST jypark FLUENT 2 August 14, 2013 23:49
CFD Post: Difference between calculated surface values using different methods Shawn_A CFX 11 July 30, 2013 13:07
using METIS functions in fortran dokeun Main CFD Forum 7 January 29, 2013 04:06
User defined remeshing vs ICEM CFD replay remeshing vmlxb6 CFX 0 October 18, 2010 01:58
