intake/inlet air filter in gas turbine power plant
Old   May 3, 2014, 20:44
Default intake/inlet air filter in gas turbine power plant
choirul mutamam
zenwalk is on a distinguished road
excuse me all, i need help for power plant case. . . . . inlet air filter used to clean air from dust or other that can be fail for gas turbine. in the filter house consist of two stage, prefilter and main filter. high pressure drop is main problem in the inlet air filter. differential pressure sensor has been installed in the prefilter and main filter to measure or as indicator drop pressure. how to simulate in ansys this problem? simulate air filter until they must remove to install new filter. And if numerical analysis, how to solve the problem. thanks very much before.
zenwalk is offline   Reply With Quote
gas turbine combustor, inlet air filter, main filter, prefilter
shaft power versus RMP curve in wind turbine simulation zhenduan306 CFX 28 November 8, 2012 10:11
Need help on calculation of power coefficient for contra-rotating turbine altomos CFX 5 October 7, 2012 06:26
1d analysis and simulation of gas turbine power plant sridhar.d009 FLUENT 0 September 28, 2010 07:46
1D analysis and simulation of gas turbine power plant sridhar.d009 Main CFD Forum 1 September 28, 2010 07:38
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
