Fluent/filter/porous jump/pipe
Old   June 3, 2014, 14:00
Smile Fluent/filter/porous jump/pipe
Kevin
KevinC is on a distinguished road
Hi everyone
I'm trying to simulate a flow through a strainer (filter) in a pipe with a well-rounded expansion before, and an 90 degrees elbow after it, in 3D, using Fluent. To simplify, just considerate a pipe with a 'filter' inside : To do that I've modeled the filter as porous jump.
__________________________________________________ _______________
!wall
inlet !wall filter outflow
________________________________________________!w all_____________
My boundary conditions are : Velocity_inlet - Outflow - Wall - and Porous jump
From the experimental data I get the permeability and the pressure jump coefficient for the porous jump condition.
I run it with a k-omega turbulence model.
But the results are not correct, it seems that it doesn't use the porous jump, and something weird, the pressure is higher after the filter, but it should be the contrary..
Any help would be appreciated
Thanks
Regards
Kevin
KevinC is offline   Reply With Quote
filters, fluent 14, porous jump bc, pressure drop
