Defining contact regions in FSI problem.!!!
Old   June 12, 2014, 00:33
Default Defining contact regions in FSI problem.!!!
sree
sreemvlk is on a distinguished road
I am doing a Two way FSI problem using Transient structural and CFX in Ansys Workbench 14.0,..The problem is to study the interactions of a flat plate placed horizontally and axial water flow over it..
There are 14 faces of the solid of which 4 of them are fixed...and two of them acting as the interface..I know how to do the setup.
But i am facing a problem in defining the contact regions between solid and fluid.
I am not getting the result with default contact region..Do I need to cancel the default contact region and make new ones,,,??
If so, does the contact region should be the same as "interface" between solid and fluid where the data is interchanged??..
Please help..
sreemvlk is offline   Reply With Quote
seek help:a problem about FSI caosheng ANSYS 11 November 21, 2017 13:21
Missing contact regions in Fluent cstebbings FLUENT 0 February 24, 2014 14:05
[ANSYS Meshing] 2-Way FSI meshing problem using ANSYS 13 workbench john881129 ANSYS Meshing & Geometry 0 January 9, 2012 01:19
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 04:08
defining regions Harriet Pearson Main CFD Forum 0 February 19, 2004 12:44
