Problem unstructured mesh domain drilled by a cylinder
Old   July 16, 2014, 16:40
Default Problem unstructured mesh domain drilled by a cylinder
obliz is on a distinguished road
Hi guys ,
I have a problem with an unstructured mesh of a simple domain . It is a parallelepiped drilled by a cylinder that represents the shoe of a tribometer . The bottom of the tribometer is only two micron ( unity of icem cfd ) from the base . When I generate the mesh with robust octree ( all tri , patch dependent ) , there is a problem of matching between the bottom of the shoe and the side surface of the cylinder : the mesh cannot reach the curve that connects this two surfaces , and it generates wrong shells ; this thing makes not good the mesh . Can someone help me ? Is it maybe a problem of tolerance between surfaces or geometry ? Or is that a problem of volume meshing ? Thank you
obliz is offline   Reply With Quote
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Accuracy problem of HO schemes on unstructured mesh, HO scheme gives 1st order result gemini Main CFD Forum 12 December 27, 2011 21:01
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
Public domain unstructured mesh generator Fabien Coppens Main CFD Forum 1 October 15, 1998 12:33
