Ansys Workbench moving heat source and laser cladding?
Old   August 13, 2014, 07:45
Question Ansys Workbench moving heat source and laser cladding?
Eugenia
eap88 is on a distinguished road
Hi everybody!
I´ve become a member of cfd-online because I´ve started a new job and the´ve asked me to obtain a laser cladding process simulation for a blisk airfoil. I´ve started to learn how to use Ansys (I learnt a little bit APDL at the university) and I think I am ready now more or less.
The thing is that they prefer to use Workbench than APDL. And to simulate the cladding I think that I need a moving heat source in wich all the deposition elements are killed and "revived" at each time step. I´ve tried this writting a code for APDL and it works.
But I´m not able to get it for Workbench. I have read that I can add an APDL command order in Ansys Mechanichal buth I don´t know how to add the loop in the transient thermal...
So the questions are:
1. Does anybody know if it is possible to simulate a laser cladding process (which means moving heat source and birth death elements) in Workbench?
2. If it was possible...how?
Thank you very much in advance for your help!
eap88 is offline   Reply With Quote
Old   April 27, 2016, 01:30
Smile laser welding
chellupavankumar@gmail.com
iampavan31 is on a distinguished road
Hi....This is pavan Kumar ,doing mtech in engineering design.I am doing a laser welding of dissimilar metals using a semiconductor diode laser up to 3 kW power in ARCI,hyderabad . I am writing APDL code also, but there is some problem with code.kindly Can you help me with the code.Iam trying with work bench also.If we crack the simulation with work bench.surely I wil help you
thankyou
Email id:chellupavankumar@gmail.com
iampavan31 is offline   Reply With Quote
birth & death, laser cladding, moving heat source, workbench 14.5
moving heat source on fluent isaac FLUENT 3 February 2, 2017 04:21
laser moving heat source simulation in ansys rajat27feb ANSYS 0 September 6, 2012 06:41
[ANSYS Meshing] Laser moving heat source simulation in ansys rajat27feb ANSYS Meshing & Geometry 0 September 6, 2012 02:41
moving heat source Körby ANSYS 0 July 8, 2010 08:21
udf with moving heat source Ryan FLUENT 0 April 10, 2003 19:13
