August 13, 2014, 16:56 |
Stent Crimping in ANSYS
Rep Power: 11 |
I am trying to simulate the ‘crimping’ of a certain geometry which can be considered as an elementary part of a cardiac stent. The geometry is basically a ring with a uniform cross section – the outer surface of this geometry falls on the surface of a cylinder. I am applying the load as a pressure on the outer surface. What I expect is the entire ring to be compressed / ‘crimped’ to a smaller radius due to the external pressure. But when I run the simulation, the entire geometry seems to translate and move sideways. Can you tell me what I am doing wrong?
See attached for files and results screenshots. Also here: http://files.engineering.com/getfile...ping_files.zip |
August 20, 2014, 09:31 |
Rep Power: 11 |
Issue resolved.
November 17, 2020, 16:13 |
project
Youssef
hi, i'm trying to do the same simulation on the same type of stent, does it bother you to send me your project ? it's for a university project.
ansys, crimp, deformation, stent, stress |
Pro/E to ANSYS Parameterization Guide | Trues | ANSYS | 4 | April 18, 2018 05:52 |
[ICEM] Aneurysm + Stent Meshing ! | rjd150 | ANSYS Meshing & Geometry | 5 | May 11, 2016 12:21 |
Fluid structure interaction | jnattia | Main CFD Forum | 25 | May 21, 2015 09:16 |
Ansys HPC licensing policy | assafwei | ANSYS | 0 | June 29, 2014 16:00 |
Exporting results from CFX to ANSYS ?? | sohail ahmed | CFX | 1 | December 20, 2007 01:10 |
