Visualize the trapped particle coordinates at the wall
Like Tree2Likes
  • 1 Post By edoan
  • 1 Post By edoan
Old   December 1, 2014, 19:02
Default Visualize the trapped particle coordinates at the wall
S. Morichika
Saidul is on a distinguished road
I have the trapped particle coordinates in .txt file and I would like to visualize it at the wall. I am using ANSYS FLUENT for my simulations. My case is 3D. How can I visualize the particles by using its coordinates?
Thanks in advance for your help.
Regards,
Saidul
Saidul is offline   Reply With Quote
Old   December 2, 2014, 09:03
edoan's Avatar
Ethan Doan
edoan is on a distinguished road
You can Visualize the trapped particles by enabling the accretion option in the DPM settings. With this option you can display where the particles are accumulating on the wall with contours
Saidul likes this.
edoan is offline   Reply With Quote
Old   December 2, 2014, 19:29
S. Morichika
I enabled the Accretion option from the physical model of DPM. Could you please tell me how can I do it? I will be happy if you tell me the detail procedure.
Thanks in advance for your support.
Regards,
Saidul
Old   December 3, 2014, 10:36
edoan's Avatar
Ethan Doan
Hey Saidul, Once the option is enabled and you have run your sim the procedure is the same as if you were plotting velocity or pressure contours on a surface. Select the surface you want to see the accretion (must be "trap" surface in the particle boundary conditions or you wont see anything) and select "particle accretion" from the list of variables availbe to plot.
rmn_990 likes this.
Old   December 3, 2014, 18:02
S. Morichika
Hi Edoan,
Thanks for your help.
coordinates, trapped particles, visualization
Divergence in AMG solver! marina FLUENT 20 August 1, 2020 11:30
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Radiation interface hinca CFX 15 January 26, 2014 17:11
LES in DES can't be actived! shenying0710 CFX 17 January 23, 2014 04:45
visualize wall deposition Jovana FLUENT 2 May 11, 2011 08:30
