December 3, 2014, 09:33 |
3d wind turbine lift drag
sitasma
Rep Power: 12 |
I have simulated the flow around wind turbine using sliding mesh technology. I am not sure how to refer the direction for lift and drag forces. my center of rotation is in (0,-0.017,69.9) and axis of rotation is y axis.
Should i calculate lift and drag in stationary condition or the rotating condition? i have used rotating condition and got the results for one blade but i am not sure it is correct or not. lift (0,0,1) and drag(0,1,0) these are the vectors i used. i have also used the unsteady flow. so i am not sure how many time steps, delta t, and number of iterations per time step should i put. i used 0.1 as delta t and 300 time steps with 30 iterations per time step. |
Air Flow Analysis around a Wind Turbine | NightHawkRaven | FLUENT | 4 | August 12, 2014 17:18 |
drag and lift calculation of a cylinder in wind tunnel | fewgoodmen | Main CFD Forum | 4 | February 24, 2014 15:05 |
FSI - Wind Turbine | AUN | CFX | 13 | August 29, 2012 16:44 |
Negative lift in Modeling an airfoil design for wind turbine | Ram209e | Main CFD Forum | 3 | August 8, 2012 22:39 |
lift and drag Marine Turbine | saclu | FLUENT | 0 | May 13, 2011 04:43 |
